want a posi - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2003, 11:34 AM
Post want a posi
I got a 85 cutlass supreme. Its only got a one legger. i was wondering if there was a way i could change the rearend in it into a posi. If so how would i go about doing it. If anyones got any ideas that'd be great.
Old 04-03-2003, 01:25 PM
mikeweyman's Avatar
Last journal entry: 2 years later
Post
you should be able to switch it out in half a day if you have the right replacement, maybe one out of an old camaro or something, make sure it fits before you buy it.mike
"BE ALERT" the world needs more lerts
Old 04-03-2003, 02:49 PM
BOBCRMAN@aol.com's Avatar
Post
Only way to change it into a posi is to buy a posi unit and have it installed by a competent rear end guy.
Old 04-03-2003, 10:25 PM
OddsNEnds's Avatar
New Member
Post
Someone on this board mentioned that they did a guts swap with a 3rd gen. Camaro. Maybe try the search feature and see what you come up with.
You can install a posi unit from various other 7.5" GM rear ends. Which ones exactly I am not totally sure of. Certain S10 pick ups, certain 3rd. gen. Camaros and G body Monte Carlo SS's would have posi units.
I agree with Bob that if you don't have experience setting a rear end, you should take it to someone that does.
There is another option, that would be to swap out the whole rear end with one that does have posi. A Monte Carlo SS rear end would swap right in with no mods. If you want a stronger rear end, you can try to hunt down a Buick Gran National or T-Type rear end, these also bolt right in with no mods necessary and come with a 8.5" gear set that is much stronger than the stock unit in your Cutlass now. Both the SS and Buick rears would also come with better gear ratios too.
Al
OddsNEnds
<a href="http://www.hawaiianflavor.com/Malibu/malibu.html" target="_blank">It's not perfect, but it's mine.</a>
[ April 04, 2003: Message edited by: OddsNEnds ]</p>
