Want to put a pontiac 400 in a chevy set up - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2009, 08:24 AM
Tonythefish's Avatar
Last journal entry: final pics
Hello ,
I have a 32 ford set up for a chevy motor but I would now like to put my fresh pontiac 400 tripwr set up in it . Is there a adapter motor mount that someone sells to do this or do I have to redo my frame mounts .
Thanks, Tony
Old 05-01-2009, 12:21 PM
fast68's Avatar
likes chevy trucks & boobies
do you already have the common 70s up clam shell style mounts? if so just get ones for pontiac etc engines. they are just a tiny hair different is all, than chevy ones.
Old 05-01-2009, 08:19 PM
Speedshift_Sam's Avatar
Mekanicus Automotive Group
Chassis mounts
Now I'm not quite sure how the mounts are setup on your chassis, but I do know that apart from being a little wider than your typical Chevy, the Pontiac block mounts are in a slightly different place. If your chassis mounts are short in length, you may not have a single problem at all, considering that late Pontiac mounts are nearly five inches from nut to bolt-hole. However, if the mounts are long, you might have interference on the front side. Do note however, that the poncho's mounts are further apart laterally than your typical SBC. Try stuffing a 462 stroker Pontiac in a 73 Camaro, it won't work unless you use the chassis mounts from a similar F-bird. (Which are nearly 2 inches shorter in height, for all of you keeping tabs on my knowledge of such things.) Take note on not only the distance between mounts, but also their length, and distance from the front of the block. It may, simply, drop right in depending on your style of chassis mounts,
Chevy block interchangeable with Pontiac / Olds/ Buick JACK Engine 10 04-20-2011 07:16 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 09:11 PM
Need some help building chevy 400 pontiacpower Engine 6 02-20-2006 07:00 AM
pontiac 301 to chevy 400 ????? hotrodkeith Engine 5 01-23-2006 06:03 PM
Graft a pontiac engine into a 63 chevy truck Raphyel Engine 10 09-02-2004 01:19 PM
