Want to put a turbo on a 305 chevy - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 09-30-2013, 06:31 PM
Banned
Go with a Bosch 044 fuel pump. But ditto the above post. It's not rocket science.
  #32 (permalink)
Old 09-30-2013, 07:16 PM
Originally Posted by bygddy View Post
I'm sure its not proper etiquette but if your doing a TPI 305 turbo build, you really need to spend some time on thirdgen.org
Another good site is http://www.theturboforums.com/
There are many many 305 builds, many stone stock builds making stupid power, including my all time fav "the grenade" thread.....
Your goals are easily acheivable using a simpe eBay turbo, eBay inercooler, walbro fuel pump, injectors and tune. Nothing more....
Its actually that simple.....the issues always arise when the tune is wrong, or oil feed, oil drain, etc.....these are the reasons guys break stuff. Find a tuner in your area with knowledge of gm's TPI motors, one that has done turbo tune's before....again, thirdgen.org can help you here.
Thanks, I've been on thirdgen.org. So you guys are saying with the stock motor and the correct turbo and tune I could be at 350 hp? No cam/head/lower the comp ratio neccessary? Just upgraded fuel system and ebay turbos?
  #33 (permalink)
Old 09-30-2013, 07:20 PM
Proud LOSER
The right sized turbo, an eBay intercooler, the right fuel supply and tune.
350hp? Sure, if you ran it with a couple plug wires off lol.
  #34 (permalink)
Old 09-30-2013, 07:57 PM
Banned
A lot of people like spending other people's money. A mild cam would help but even that isn't needed. I would just get a cheap white box RV cam, they're like 75 bucks for the kit.
Leave the rest of the engine alone.
  #35 (permalink)
Old 09-30-2013, 09:33 PM
64nailhead's Avatar
Robyyo, my son and I are in the part gathering process for a rear turbo setup on a 327 TPI motor. I was planning on starting a thread with some questions, so I'll ask them on this thread as you have a relativley similar setup. I don't want to upset the apple cart though by hijacking the thread!
What do you guys think in terms of pipe size to the intake from the rear of the car? Smaller is better for me due to space limitations but I don't want to limit the amount of air flow below what out stock TPI throttle body will handle. I would use 2" if it would work, but I could use 2.5" if needed.
F-bird mentioned that the rear turbo will cool the intake charge enough to eliminate the need for a CAC; if we keep the boost in the 6-10 psi range will the intake charge be cool enough?
We are using a Comp 12-236-12 cam with ported stock 70cc heads with 1.94/1.50 valves; CR is 8.95:1 and we running forged Probe flat tops. We have an adjustable fuel pressure regulator and are using 27 lb/hr injectors and controlling it with an aftermarket controller(ecm). Will we be alright with 93 octane? Or to what boost level will be OK with 93 octane?
Tech, hopefully you consider the 327 one step ahead of a 'fosdick' (where do you come up with this stuff)
  #36 (permalink)
Old 10-01-2013, 05:02 AM
64nailhead's Avatar
The heads are 185. They have 1.94 intakes and are quite heavily ported. The throats were cut and they have a 4 angle valve job done. They were machined for larger springs and positive valve seals. I have to admit that in hindsight, we should've bought a different set of heads instead of putting the $ into these ones, but, live and learn.
Any thoughts on boost level on pump gas (93)?
  #37 (permalink)
Old 10-01-2013, 07:39 PM
cal1320's Avatar
Read this thread. It's 164 pages of TPI induction with twin turbos on a cast piston, cast crank $300 junkyard 350 grenade (it never did blow up). What worked, what didn't, mega HP and Torque on a very small budget. An amazing journey into the turbo world. It's very long, but well worth the read. http://www.theturboforums.com/thread...part-2-to-come
The Following User Says Thank You to cal1320 For This Useful Post:
64nailhead (10-02-2013)
  #38 (permalink)
Old 10-01-2013, 09:34 PM
Proud LOSER
See post#40...
Marty's experience is certainly not the norm, and its always the guys who don't actually care if they break parts that seem to do well when pushing the envelope. The thread does offer alot of insight into "doing lots for very little" and is a very entertaining read. Again, not even in the realm of normal but offers a lot of good info.
  #39 (permalink)
Old 10-01-2013, 09:39 PM
Banned
Not in the realm of normal... Because? Oh, he had a good tune. There's no magic or hocus pocus.
  #40 (permalink)
Old 10-01-2013, 09:59 PM
Proud LOSER
No no lol, more so there is a limit to what a "stock" lower end will take.....and he didn't always have a good tune, he almost hurt it several times....that's what I meant by "the norm"....hey, im on your side here lol, we have several younger guys around here running big HP on stock parts with boost..... I have ridden in an 80's G-body with a baby LS and twins that puts down 700+ to the ground and the motors a $700 junkyard piece with 80000km on it.....its disgusting really lol.....when the tune is right, its incredible what a turbo motor will take over a N/A screamer, supercharging or spray.....its by far the easiest on parts.
  #41 (permalink)
Old 10-01-2013, 10:09 PM
vinniekq2's Avatar
do the math on any engine combination,then look where most failures occur?and what causes the failure? Then look at diesel technology,,,,,
fill in the blanks yourself
  #42 (permalink)
Old 10-02-2013, 02:15 AM
64nailhead's Avatar
Big read is an understatement! It's 164 pages (not posts - PAGES!). I'm upto page 40 and it, if nothing else, is entertaining. Also, it is making me feel better about trying a 5-8 psi setup without catastrophic results.
I still haven't found much about plugs, hotter or colder, and timing, more or less with boost. I'm quite familiar with intake temps and what needs to be done with the timing as temps go up, but??
Still reading, still learning. Thanks for the link.
  #43 (permalink)
Old 10-02-2013, 07:26 AM
Banned
typically ring lands, and detonation causes it.
Not really related to diesel technology at all considering how a diesel operates.
  #44 (permalink)
Old 10-02-2013, 07:36 AM
vinniekq2's Avatar
AP72,you missed the point totally,and I am surprised,,,
think more along the high RPM and high heat combination.
A lower RPM turbo seems to last longer than a high RPM N.A. engine making the same power.
A diesel is low RPM,rarely has valve train problems
diesels use high boost and rarely have sealing issues
you can add to this
  #45 (permalink)
Old 10-02-2013, 08:02 AM
Banned
you can add to this
Valvetrain issues are completely separate from turbo issues, and are usually RPM related, as you noted.
Diesels rarely have sealing issues because the blocks, heads, and usually head bolts are designed to take much higher pressures than most gas engines, this is less related to the turbo and more related to how a diesel works and is subsequently designed.
FWIW there are some "higher" rpm diesels out there. And LOW rpm is usually the area where detonation is hardest to control for a gas engine, so you have to trade valvetrain stability for detonation resistance.
At this "back yard hotrodder" level you're way over thinking it though. Good turbo selection, intercooling, and tune are the 3 areas of highest concern. Hit those three and you should be alright with a conversion of most factory NA engines.
These power levels seem high for a stock SBC but consider that many 4 banger guys are making 300-400hp with slapping a turbo on a ~2.0L engine, that puts a 5.0L sbc in the 750+hp range. And I'm not referring to just 4 valve dohc engines, 2 valve sohc engines in that area are making that power too, on stock long blocks, usually on E85, and sometimes 93 octane.
Can I put a turbo 350 in place of 700r4? eric32 Transmission - Rearend 7 08-23-2008 01:51 AM
chevy 305 stock,ported polished, Holset H1E turbo. 74chevyflat Engine 19 06-02-2008 04:03 PM
how to put a turbo on a sb 400 mrbull30 Engine 10 04-20-2007 04:11 PM
Can you put a 350 transmission on a 305. CCR Transmission - Rearend 7 04-28-2005 03:41 PM
What are the best heads to put on a 305? CCR Engine 6 11-06-2004 01:50 PM
