Want to put a turbo on a 305 chevy - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 10-02-2013, 10:22 AM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by 64nailhead View Post
Tech, hopefully you consider the 327 one step ahead of a 'fosdick' (where do you come up with this stuff)
Fearless Fosdick was a failure at everything, so anything that won't work properly earns the title of fosdick....
Al Capp's Fearless Fosdick: Comics & Underground Comix
  #47 (permalink)
Old 10-02-2013, 10:36 PM
KA67_72's Avatar
I got tired of reading all the posts so it may have been mentioned. Single HX-35 off a cummins for cheap quality turbo, or something in the 60mm area. Lag from a bigger turbo will take all the fun out of it without bigger heads. Comp turbo cam. Call them. Hypers are supposed to be good for turbo but I run forged in all my turbo motors. Not gapping your rings enough will break every type of piston every time. 882's can flow but are prone to breaking.
Kevin
  #48 (permalink)
Old 10-02-2013, 10:40 PM
Banned
Hx35? Really? Kinda small... A 60mm turbo is a good place to start though. Very common size for a street v8 in this displacement range.
  #49 (permalink)
Old 10-03-2013, 02:07 AM
Originally Posted by cal1320 View Post
Read this thread. It's 164 pages of TPI induction with twin turbos on a cast piston, cast crank $300 junkyard 350 grenade (it never did blow up). What worked, what didn't, mega HP and Torque on a very small budget. An amazing journey into the turbo world. It's very long, but well worth the read. http://www.theturboforums.com/thread...part-2-to-come
I think that proves it. A forged bottom end isn't necessary. I'm going to stick with the stock 305, keep the tuning right and see what kind of performance I get.
  #50 (permalink)
Old 10-03-2013, 05:19 PM
64nailhead's Avatar
I agree, especially for a first time try with a turbo. That thread about the 'grenade' is absolutely crazy. I know it made me feel better about trying an 8-10 psi setup.
Check this out, http://www.junkyardturbos.com/Rear-M...wholesale.com/ a pretty low budget way to pick up some HP on the cheap and easy.
I believe that the you should spend your money on a quality BOV and wastegate (no ebay $60 units) like Tial and save your engine upgrades until after you get the turbo setup running on mild boost. I would also recommend some form of AFR sensor to eliminate all of the guessing.
Like AP mentioned a couple of pages back, start the boost low and creep it up slowly. It will allow you to learn how to get the tune right without breaking. And if the worst happens, 305 are cheap and plentiful.
Good Luck.
  #51 (permalink)
Old 10-03-2013, 07:36 PM
Banned
I wouldn't worry about pricey bov's and waste gates, spend it on fuel. If you insist on running gas start with 100 or 110 for prelim tuning, or just go with an e85 system. Avoiding detonation is key and fuel is the cheapest way to do that. Inter oiling helps too and also gives you a denser charge when you get into higher boost levels.
AVOID detonation at all costs! Most important thing to making it work.
  #52 (permalink)
Old 10-03-2013, 08:29 PM
Proud LOSER
+1
Like ap said, make sure your full of good fuel before you the key the first time, unless your versed in HP tuners or some form of stand alone management its going to need too be tuned, on a dyno. There are several guys on thirdgen that can direct you to a safe "mail order" tune to get it up and running on the dyno, race gas is going to be your safety net and make sure you use it. Once you have a safe conservitive tune on the dyno get it out on the street and do some data logging. Dyno's are a great tool but cannot factor in all the variables of real life drive cycles. Once you have some street time and collected enough data to be comfortable using high octane pump gas (92+) then you can make your adjustments with timing and boost in very small increments. There isn't a lot of room for mistakes so don't get greedy. The urge to up the boost and let it eat will be strong.....ignore it.....be smart and you should be able to easily surpass your hp goals and live a long happy life.
  #53 (permalink)
Old 10-03-2013, 11:45 PM
Megasquirt.
  #54 (permalink)
Old 10-04-2013, 12:18 AM
The more I look at turbocharging the more I'm amazed at what you can do with these things. It's like all the conventional engine building goes out the window, all you need to do is stick a hair dryer on a stock motor, tune and go.
  #55 (permalink)
Old 10-04-2013, 12:25 AM
vinniekq2's Avatar
not exactly
at 8 pounds boost you could have 1.5 times what you had with no boost
IE: 300 horse motor becomes 450 hp
160 HP motor becomes 240 hp
start with good engine and the difference is more
  #56 (permalink)
Old 10-04-2013, 10:15 AM
spinn's Avatar
I have no problems with your choice to stay 305. They are cheap and plenty. My c10 has a 305 that is supercharged. Did 5 psi and 9 psi setup for daily truck driving 0-5500 rpm. Performer cam with vortec heads and 3000ish stall. Makes more than enough smiles. Do not over cam, keep it in the operating range, and figure your compression ratio.
If you are racing, staying with the 305 is a little silly, but whatever.
  #57 (permalink)
Old 10-04-2013, 02:12 PM
No I'm not really planning on racing with it, just a healthy street machine with some grunt, but not overdone.
  #58 (permalink)
Old 10-07-2013, 08:42 AM
Vortec 305 with twin turbos on a 0411 PCM.
GM Performance :: View topic - 98 GMC Twin Turbo with 12200411 PCM--- It's Alive
peace
Hog
  #59 (permalink)
Old 10-07-2013, 01:18 PM
Project89's Avatar
i dont have time to read the whole thread but i did read a few posts but im going to chime in anyways
if the engine has a tpi intake on it u want a cam thats
218/218 @ 50
the goto turbo cam for the 350 tpi guys is the summit 224/224 but with a smaller engine the cams act larger
being as the tpi will have a slightly higher rpm range on the 305 u may be able to get away with the 224/224 summit cam , my good friend currently has a 305 tpi turbo build on thirdgen.org and is using a cam slightly larger then that
for a turbo pick up a ebay gt45 its cheap dead reliable and will make way more power then u want.
im not a fan of the ebay headers at all but if u cant weld up ur own set they are the cheapest way to go to get u into the turbo game.
i have personally had a few sets of the ebay sbc single turbo headers in my hands from friends who have bought them. out fo the box they will work but the welding is horrible on them. all my friends brought them to me for me to clean them up and reweld a few sections.
if u go this route bring them to a local welding shop and have them clean up the welding and slag left around the inside of the turbo flange and they will be fine for a year or 2
for a bov get an ebay rfl bov for 35$'s theese are simple piston type valves with one moving part , they work flawlessly and do not leak nor can they every break
for an intercooler setup the ebay kits work great ive used theese kist on tons of cars , for a camaro u want the kit that has the 32x12x4 with 3 inch in and outlets bar and plate intercooler that comes witht he 3inch aluminum tubing coupler and clamps.
megasquirt is a great choice its what i run on mine
lastly u will need to do some fuel system upgrades , a walboro 255lph pump should be fine for u as it will support around 500whp
and u will want 50 or 60# injectors
one very import part of this whole thing if u want it to live is the top ring gaps in the pistons, if they are setup for na the rings will butt together and break under boost, even if the engine is used u need to pull the heads and check the ring gap .007 to .008 per inch of bore is a good place to start with the ring gap
Last edited by Project89; 10-07-2013 at 01:25 PM. Reason: added ring gap information
  #60 (permalink)
Old 10-07-2013, 03:29 PM
spinn's Avatar
Im not having ring gap issues. That I know of anyways. We cut the base of the exhaust manifold and weld the T flange on. The stock cast manifolds work awesome, and welds hold fine ( been over 18 months).
How much boost are running, that might be the problem.
Can I put a turbo 350 in place of 700r4? eric32 Transmission - Rearend 7 08-23-2008 02:51 AM
chevy 305 stock,ported polished, Holset H1E turbo. 74chevyflat Engine 19 06-02-2008 05:03 PM
how to put a turbo on a sb 400 mrbull30 Engine 10 04-20-2007 05:11 PM
Can you put a 350 transmission on a 305. CCR Transmission - Rearend 7 04-28-2005 04:41 PM
What are the best heads to put on a 305? CCR Engine 6 11-06-2004 02:50 PM
