Want to put a turbo on a 305 chevy - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 10-07-2013, 03:05 PM
Project89's Avatar
Originally Posted by spinn View Post
Im not having ring gap issues. That I know of anyways. We cut the base of the exhaust manifold and weld the T flange on. The stock cast manifolds work awesome, and welds hold fine ( been over 18 months).
How much boost are running, that might be the problem.
it depends on how much boost u run , at only a few psi stock ring gaps are perfectly fine , unless u dont have an intercooler then they could be come a problem
even if the plan is only to run a few psi i still like to open the ring gaps , because as most of us know boost is adictive and theres always the urge/itch to turn the boost up , opening the ring gap up when u first start lets u turn up the boost in the future if u so desire
  #62 (permalink)
Old 10-07-2013, 03:07 PM
Project89's Avatar
this is what happens when u get the urge to up the boost with a stock ring gap
that happened at a measly 12 psi
it broke the top ring the ring land and finally the second ring
  #63 (permalink)
Old 10-07-2013, 03:12 PM
spinn's Avatar
I ve used the 8 pound spring before, but leave the 6 in. I have used the 9 psi pulley on the blowers. I set the stuff I build to work at 4-6 , real nice smooth performance.
  #64 (permalink)
Old 10-07-2013, 03:14 PM
Project89's Avatar
yeah thats considered very mild boost when it comes to a turbo at those levels i would trust stock gaps as long as the tune is in check
Can I put a turbo 350 in place of 700r4? eric32 Transmission - Rearend 7 08-23-2008 01:51 AM
chevy 305 stock,ported polished, Holset H1E turbo. 74chevyflat Engine 19 06-02-2008 04:03 PM
how to put a turbo on a sb 400 mrbull30 Engine 10 04-20-2007 04:11 PM
Can you put a 350 transmission on a 305. CCR Transmission - Rearend 7 04-28-2005 03:41 PM
What are the best heads to put on a 305? CCR Engine 6 11-06-2004 01:50 PM
