Want to put a turbo on a 305 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2013, 11:11 PM
Hello friends, I've got a 69 firebird with a 305/700r4 out of a 84 trans am. I've already got the tpi set up for it and want to be making in the 350hp neighborhood at the fly wheel. Now before everyone goes with the old "ditch the 305 and go with a 350" spiel just entertain the though that I'm going to stick with the 305. I've been doing some research and I think the best route to make some HP out of this motor is to go with turbos. Does anybody out there know how I should go about setting this deal up? I want to keep the boost moderate so I don't shatter the bottom end, fry the trans and destroy the rear end. Any help would be greatly appreciated.
Old 09-29-2013, 11:41 PM
vinniekq2's Avatar
fbird88 is your guy,probably. 7-8 # boost and you will make lots of street hp.
post all the engine specs and if its new,test head flow before assembling.
Old 09-30-2013, 04:46 AM
Proud LOSER
Check out thirden.org
Lots of good info on Turbo 305 TPI builds
Good luck
Dave
Old 09-30-2013, 07:26 AM
Banned
If you're just chasing 350hp then I wouldn't even though the heads. Find a cheap "RV" or similar type cam, run an exhaust pipe off the stock manifolds to a single turbo upfront, intercool it, and run EFI (TPI is a good system). You'll be way past your power goals for minimal investment.
A single T61 is a common cheap turbo that will work, there are better ones out there but they cost more.
Old 09-30-2013, 10:33 AM
Here's some parts I have laying around that I think would make a good combo- A comp thumper XE274, 1.5 comp roller rockers, a pair of 1x5/8 headers and a ported MAF TPI set up with the stock size throttle body. With this set up will I need a custom chip or upgraded injectors, or will all this work with the HP levels I'm looking for?
Old 09-30-2013, 10:36 AM
vinniekq2's Avatar
post the specs of the cam and the turbo you have in mind?
Old 09-30-2013, 11:05 AM
Duration @ 0.006": 274 / 286 Duration @ 0.050": 230 / 236
Max Lift w/ 1.5RR: .487" / .490" Lobe Separation: 110
Lobe ID#'s: 5445 / 5208 Intake Centerline: 106
Haven't found the turbo yet. What size would be correct for this application?
Old 09-30-2013, 11:30 AM
vinniekq2's Avatar
I would use a garret gt-35 or there abouts.6-8 pounds boost maybe 375-400 hp.
I would not use a thumpr cam. a turbo cam is usually a little shorter duration on the exhaust side.look at 224/218 duration or in that area.
like fbird said,port the heads
Old 09-30-2013, 11:34 AM
techinspector1's Avatar
Wiki Edits: 326
You'll have hundreds of questions before you get this project completed. Do yourself a huge favor and read through MacInnis' book. I'ts back to one of my favorite sayings, "You don't know what you don't know"......
Amazon.com: Buying Choices: Turbochargers Amazon.com: Buying Choices: Turbochargers
Nothing wrong with buying used books. I do it all the time to save money. It's amazing to me that you can pick all the information you need from the author's brain for under 10 bucks delivered to your door.
Old 09-30-2013, 11:50 AM
Wiki Edits: 326
114 LSA for runnin' alcohol.
110 LSA for runnin' gasoline.
Banned
He won't need a reverse pattern cam UNLESS he messed up on the turbo selection. He will need shorter duration though. A cheap "RV cam" (typically 204-214 duration) will work well. A GT35 will work well for low-mid rpm but won't like high rpm at all.
As for "a chip" you can forget that. A "chip" ain't gonna cut it. You'll need a different more easily tuned ECU. And injectors, and a fuel pump.
Porting the heads will give you more power, but its not needed at all to hit 350hp. Nothing wrong with pushing for 500hp instead though...
Originally Posted by F-BIRD'88 View Post
To turbo charge the 305 TPI engine I would replace the cylinder heads
use a high perf head from a 350 with 64cc + chamber and port them to improve flow
1.94x 1.50 valves. This will drop the engine compression ratio to allow decent turbo boost.
The "083" casting stock head from a 350 TPI motor is not bad once its ported.
Ditch the stock exhaust manifolds. Get some headers. Get a turbo compatible camshaft.
Many of the 305 TPI motor had a tiny "peanut cam" that will choke power.
The stock TPI intake could use some porting. Possible "Siamese porting"
You don't need the long tuned tubes once its turboed but you do need the added flow.
You need to add port flow as well as turbo it for power.
Rear mounted turbo system. The stock bottom end is plenty strong for turbocharging.
STSTurbo.com: Buy Custom Turbo Systems for Sale
is a 76 cc combustion chamber too much? Will such a low comp ratio kill power? Or will the turbo make up for it?
Old 09-30-2013, 11:59 AM
Adding a 76cc head in place of the 58cc 60cc 4416 head yess will drop the compression ratio a lot.
But by doing that you can hit it with a LOT of boost on (92) pump gas with out
detonation.
you want to port the ehad too to improve port flow.
Don;t be shy with the porting.
Some 76cc heads are crappy. not worth it. avoid 882-462624 etc.
What is the head casting numbers you got there.
Flat top pistons? dished pistons?
You want to get the cr to 8.5:1 or a bit less.
They're the 333882 castings. I haven't opened up the motor yet.
Old 09-30-2013, 12:01 PM
Wiki Edits: 326
The lower the static compression ratio, the more boost you can shove into the motor. Use 76cc heads with these forged 24cc pistons to generate a 7.5:1 static compression ratio, then tailor your turbo for 10 lbs of boost on pump gas. Don't worry too much about squish on a blown motor, the blower/turbo will homogenize the mixture on the way in. Also, don't spend time and money on porting heads. I can guarantee you that with 10 psi pushing the mixture into the motor, you'll make plenty of power with stock port and valve sizes. Also, turbo lag can be overcome with a small shot of N2O. You'll learn all this stuff if you read the book I linked for you.
http://www.summitracing.com/parts/srp-139632
Old 09-30-2013, 12:07 PM
I'll get that book. Those pistons in the link are for a 350.
Can I put a turbo 350 in place of 700r4? eric32 Transmission - Rearend 7 08-23-2008 01:51 AM
chevy 305 stock,ported polished, Holset H1E turbo. 74chevyflat Engine 19 06-02-2008 04:03 PM
how to put a turbo on a sb 400 mrbull30 Engine 10 04-20-2007 04:11 PM
Can you put a 350 transmission on a 305. CCR Transmission - Rearend 7 04-28-2005 03:41 PM
What are the best heads to put on a 305? CCR Engine 6 11-06-2004 01:50 PM
