Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Want to rebuild my 10 bolt
Old 10-17-2011, 05:57 AM
gonefishin' gonefishin' is offline
What you may see when you pull the axles is a groove worn into the axle where the brng. rollers ride cause the axle it self acts as the inner race of the brng. If you see thuis you might as well go on and get a good set of axles. I have less fear using the c clip set up if the axles are good ones not stock ones with a groove worn in to them that can be a weak spot. Never mind the new brngs. want a good flat surface to ride on. Replace the seals too but Im sure you know that.
