Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - WANTED: hints, tips, tricks, for my firewall install
Old 01-15-2012, 06:10 PM
123pugsy's Avatar
123pugsy 123pugsy is offline
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
If you want to overlap, keep the material 1/8" from the bend as you have it now and you should be able to blend the weld/grinding into the bend to look as one piece.
If its too far in, there will be a defined step after you grind off the welds.
Make sense?
