Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - WANTED: hints, tips, tricks, for my firewall install
Old 01-15-2012, 06:51 PM
matts37chev's Avatar
matts37chev matts37chev is offline
I don't understand?
Last journal entry: this is only a test
Originally Posted by 123pugsy
If you want to overlap, keep the material 1/8" from the bend as you have it now and you should be able to blend the weld/grinding into the bend to look as one piece.
If its too far in, there will be a defined step after you grind off the welds.
Make sense?
I am going to have to make some adj. and tighten it up a little in a couple of spots
its just slapped up there now, but I dont think the fit is perfect yet
I really appreciate the help
I will start on it, in the morning
