wanted: to know why im getting no spark - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2005, 04:41 PM
ive got a 91 dodge dynasty 3.3lit. v6. im getting no spark. ive changed the cam and crank adjustable sensors, new plugs and wires, coil pack was tested and its ok. both sensors are getting the 8v of its supposed to. the connections are good and tight. help me someone thanx
Old 05-22-2005, 07:18 PM
curly5759's Avatar
Check the ASD relay (auto shut down). It is in the fuse box under the hood. It powers the ignition and fuel system. Did you check for codes? If the crank sensor is not working/out of adjustment, you will get no spark. The crank sensor watches the flywheel on that model, there have been some 3.3's with cracked flywheels, but those I heard of were on minivans.
Old 05-23-2005, 12:32 AM
how would i adjust the crankshaft sensor? i just pushed it in and tightened the bolt. i should i test the asd relay if there is a way? if you can explain to me how to adjust the crank sensor and how to test the asd relay i would appreciate it very much. thanx
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Not geting any fire...No Spark bbc45473 Electrical 3 03-23-2005 09:24 PM
Spark Prob. on 69 Skylark FannyFarmer04 Electrical 3 08-14-2004 12:41 AM
no spark? montea Engine 5 03-20-2004 11:54 PM
Spark plugs sparking to the side mar10 Electrical 3 07-25-2002 05:51 PM
