wanting to build a 350hp 350. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2008, 08:29 AM
I want to build a 350hp 350.I was thinking of using vortech heads,.030 bore,flat tops ,a 292 488 cam,air gap intake,headers,port and polished.This may not be a good combo to reach my goal.It was just rolling around my head.any suggestions?
Old 09-04-2008, 09:19 AM
Easily 350 hp probably 400
Old 09-04-2008, 04:59 PM
Everything is HAMMER!
Can't remember which mag did it but they built a 355 ~9:1, stock vortecs, and a comp xe 262 that made 422hp and 450 torque. Mind you that was with 1 3/4 dyno headers and probably no accessories. But i see know reason you couldn't get ~400 REAL hp and more torque with that setup.
Old 09-05-2008, 03:28 AM
techinspector1's Avatar
Wiki Edits: 326
"a 292 488 cam"
You'd need a static compression ratio between 10.5:1 and 12.0:1 to operate the motor on this cam. That would make it a race motor, not a street motor.
"port and polished."
You might get away with wowing the geeks down at the drive-in with this, but don't say it on here. It just makes you sound stupid.
I will say one thing in your favor. At least you asked for a reasonable hp figure, not 500 like most of the dunderheads who come on here asking for combinations.
Old 09-05-2008, 08:38 AM
re:350hp350
Surely port and polishing wouldn't help air flow just a little. to be stupid .My project is a 77 nova.373 posi (my drop to 411).It has a 350 turbo .shift kit small stall .but I found a 6spd that will hard to pass up.I am going to use forged flat tops ,GMPP H beam rods (good for 500hp),have the heads worked to run a bigger cam if needed.Roller rockers. I like cams with a rough idle.but i want good low and mid range torque .But not to massive that have no vac .Air gap intake with a 600 or 650 carb.Headers definently not sure how big of primarys they make for my car .I don't want any clearance issues .These are all ideas I will change what i need to reach my hp goal.(350hp and 400 torque would be cool)Weekend hotrod gas mileage is not an issue.Thanks for replies keep the ideas coming.Were do y'all have the engine combos listed on here.Might find a more interesting one.
Old 09-05-2008, 02:35 PM
Wiki Edits: 326
"Were do y'all have the engine combos listed on here."
http://www.ryanscarpage.50megs.com/combos1.html
"I like cams with a rough idle.but i want good low and mid range torque .But not to massive that have no vac."
This is called wanting your cake and eating it too. In the real world, this is not possible. A rough idle is produced by using a late intake closing event on the cam lobe so that the intake valve is still open as the piston is coming up the bore on the compression stroke. The piston pushes the air/fuel mixture backwards up the intake tract and disrupts the signal that the carburetor uses to meter fuel at the venturi and the motor becomes inefficient, producing a rough idle and low manifold vacuum. As the rpm's increase, the situation improves due to increased mixture velocity and improved cylinder packing. So, you can run a rump-rump cam on the street by using a looser converter to get past the inefficient mode of the cam at lower engine speeds and get the motor "up on the cam" sooner, but you will make low manifold vacuum at lower rpm's.
You can have rump-rump and low manifold vacuum at lower engine speeds with a cam that closes the intake valve later or you can use a shorter cam with an earlier intake valve closing point and have good manifold vacuum at lower engine speeds with no rump-rump, but you can't have it both ways.
Again, you can impress the geeks down at the drive-in with a rump-rump cam, but the older and wiser members of the crowd will identify you as a poser. I can understand the need of some fellows to use a rump-rump cam because the car is used as maybe a dual-purpose street/strip car with stiff gears and the need to make power at elevated revs, which calls for increased duration and a later intake closing point, but those who install a long cam just to try to impress others makes me want to puke on my shoes.
Old 09-06-2008, 01:47 PM
re:350hp350
My stall converter is a 2500.The car came with it so,I'm wanting to make it run better.The carb is a quadrojuck ,headers are cheap and rusty,I was undecided about the gear's .As far as that feller getting sick in his shoes cause he doesn't like to hear an over sized cam thumping through the mufflers,thats almost un American. That sound has been putting smiles on mens faces for years.I'm not looking for a large cam but i would like it to sound more than a slite miss.IT'S ALL ABOUT THE HP.You guy's are very knowledgeable a friend at work told me about your site.This car is just a street car ,might race a camaro or mustang while cruising.
Old 09-06-2008, 01:59 PM
BS. I'm trying to figure out rumprump for my fuelie cars....
Look seriously at the new CompCams Thumpr...... the small one, not the MT, or BMT. That is exactly what they are designed for. Cruising with an idle lope and excellent mid range and throttle response.
Vacuum might be borderline, depending on what you need. You can always install a reservoir can.
You want some kind of vacuum secondary or Edel type carb. No double pumpers.
Mid range torque means 1 5/8 primary headers, 24 inch collector length on long tube headers.
Factory vortec heads are the best of any factory iron head,
EngineQuest Vortec iron 180 cc heads are even better, but not worth buying if you already have factory heads.
Decent head cleanup is beneficial. Polishing is controversial.
Old 09-06-2008, 02:57 PM
Wiki Edits: 326
"As far as that feller getting sick in his shoes cause he doesn't like to hear an over sized cam thumping through the mufflers,thats almost un American."
I didn't say I don't like to hear a motor thumping, I said it makes me ill for someone to put a thumper cam in the motor just to be a poser and have the geeks think there is a race motor in the car. It's the attitude of the poser doing it, then having to prop the motor up with a higher stall converter and vacuum reservoirs and other shenanigans to make it work on the street. It's not the motor that bothers me.
I've been around drag strips since 1958 and have seen and heard thousands of genuine high-compression race motors thumping and it's music to my ears. But for someone to install a thumper cam in their street motor just to try to impress someone and make them think there's a race motor in the car turns me off. I DON'T LIKE POSERS.
finally finished chevy 350 build redneckrodder Engine 7 05-30-2011 06:03 PM
Help on mild 350 build.. Meangreen Engine 14 08-26-2009 07:16 AM
If I were to build up a 350 awoodman Engine 56 08-28-2007 06:54 PM
How to build a 350 insayne Engine 2 11-08-2003 07:14 AM
350 Chevy build Streetmachine Engine 11 12-10-2001 04:31 PM
