wanting to build a older style 302 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2003, 05:09 PM
New Member
Question wanting to build a older style 302
I was wondering how to go about building a 302 to produce around 300 horsepower starting with a older 302 block with a 347 stroker kit. What would be best on cost as far as aluminum heads and intake and carb?
Old 12-09-2003, 05:12 PM
DoubleVision's Avatar
even so I`m not much help on Ford topics, and I`m sure some others on the board can answer your questions, I say why not build a 351W? costs about the same, more cubic inches, and makes good power and will make your 300 horse goal easier to reach.
Old 12-09-2003, 05:16 PM
New Member
I would use a 351 but its going in a 64 ford falcon this is tight fit as it is
Old 12-09-2003, 05:53 PM
mstngjoe's Avatar
Getting 300hp from a 347 is a piece of cake.
Go for 400+ and make it more interesting!
Old 12-09-2003, 07:40 PM
lluciano77's Avatar
Using Trick Flow Track Heat heads and matching cam it is easy to get over 350 hp. AFR heads would get there too.
I have a 61 Ranchero. It has the same limited space. I used head 1 5/8" Maverick headers. It took a little work but I got them to fit. I also used the Maverick radiator. The Falcon ones are just not enough.
