wanting to paint my 95 mustang... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2012, 02:17 PM
Okay so I have a 95 mustang that i want to repaint. I have already done all the body work to the car. It's been primed and now is ready to be painted. I have a color in mind, house of kolors PBC64- pearl orange. But i don't know what i need for this paint job. House of kolor calls that color a pearl base coat, does that mean i don't need a solid base coat first. Or do i need to paint it a base coat white then put the pearl base coat on top of that? This will be my first paint job. I have never done one before. So any advice is greatly appreciated and needed!!
Old 03-28-2012, 02:28 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Man you've never painted a car and you want to start out with a custom pearl job? That's almost like never driven a car then strap your butt in a top fuel rail for your first try. I would contact house of color and follow their procedure.
Old 03-28-2012, 02:54 PM
First, i'm not a man... second there is nothing wrong with being ambicious. I have been around cars all my life. And i have help from someone who has painted cars before, however they are at work right now and i had some questions. I know how to use a paint rig with a steady hand. I just have never done a car... i do airbrushing in my spair time.
Old 03-28-2012, 03:15 PM
mitmaks's Avatar
Last journal entry: Grille
No offense but bodywork let alone painting is not for amateurs. Just cause you did some airbrushing doesn't mean you can paint car. You should start out by painting a practice panel with a solid color (non metallic) and you have to have a lot of experience to paint pearls/metallics
Old 03-28-2012, 03:36 PM
Ok people now adays can not read. I did the body work already. I used an arc welder and bondo to fix the cosmetic damage to the car. I have done body work before this aswell. I have used a paint rig with an air compressor a thousand times. Just not to paint a car. I have a auto paint gun i literally just used to put on the primer. And i was not comparing airbrushing to car painting in any other way than level of difficulty. Its not easy to air brush its not easy to paint a car. Anyone who can decently airbrush knows that. Once again i am being AMBITIOUS. I know i can do it well because i have help form a very experienced auto body tech. But once again he is unreachable at work, and i was curious with questions.
Old 03-28-2012, 04:47 PM
Have you talked to your HOK vendor? The undercolor to the pearl will make a difference in the color shade it ends up being. You may want to do a couple test panels with different color base coats, then the pearl, then clear to see what the difference will be and choose the one you like.
Old 03-28-2012, 10:13 PM
Two people gave you advice (that you were asking for) and you went on a tantrum to both people. I wouldn't expect much more now.
Moral of the story is don't offend the people you'd like to help you. It's good you have the auto body tech for help.
Wanting to paint the bumpers glessen Body - Exterior 3 02-20-2009 02:43 PM
Wanting to use GM rotors and calipers on Mustang II spindles IRELAND EXHAUST Suspension - Brakes - Steering 1 04-19-2007 07:07 PM
68 mustang yellow paint packrat7201 Body - Exterior 4 05-16-2006 07:34 AM
Need advice on new paint job for 03 mustang Stallion Body - Exterior 7 11-02-2003 06:55 PM
paint 66 mustang RJL Body - Exterior 3 06-17-2003 12:11 PM
