wants to go in reverse when in neutral
i just finally fired up my top end rebuild but i had to hold in the clutch pedal the whole time because when i took off the headers i had to take apart the safety switch and clutch linkage and some how i messed up when i reinstalled everything. at first i couldn't get the ignition turn all the way back so i could get the key out. i fixed that by moving that shaft further up that slip lock nut. but when i let the clutch out when i think or seems like it is in neutral it starts to move backwards like its in reverse!! any ideas? its a sg 4 speed
Reajust the linkage if it don't work reajust the clutch.
what do you mean re adjsut the clutch? i will try adjsut the linkage. i should have paid more attention of it when i took it apart. does anyone have a picture of how everything should look?
does anyone know what might be wrong? so one told me that i might have burned out my throwout bearing!! the clutch and everything only had 8000 easy miles so i hope its okay.
this is a saginaw manual 4 speed trans?
If you think the shifter is in neutral, you let the clutch out and the vehicle move backwards... your shift linkage is messed up and the trans is in reverse I suggest you figure the linkage out and what you did wrong. Re-trace your steps on the linkage
At the Bonneville Salt Flats, first gear is known as 130 mph. |
shift linkage adjustment
Most shift linkage has holes that are supposed to line up with a 1/4 in drill shank. try to find neutral disconnect the rods at the trans arms. click the trans arms to make sure you are centered , each arm in neutral in neutral, insert the drill shank and adjust the shift rods until it fits.
Here is a photo another member posted in a thread about shifters.
Perhaps this will help. Shifter is in neutral position with alignment tool (drill bit) installed
| neutral safety | RS clone | Electrical | 1 | 09-30-2009 01:04 AM |
| Stuck in neutral | Arrowhead | Hotrodders' Lounge | 17 | 12-16-2008 07:48 AM |
| neutral switch | theuntouchables | Transmission - Rearend | 9 | 07-03-2007 02:29 PM |
| neutral safety | venom | Transmission - Rearend | 4 | 07-30-2005 08:52 AM |
| Neutral | Thom Laybourne | Transmission - Rearend | 0 | 03-02-2004 12:38 PM |
