tranny problems..
wow that sucks.. this is the main reason i only deal with local's. when building my bucket, i had the trans completely redone and installed it 6 or 7 months later. fired it up for a test and found a small leak.. called and they sent a tech to my house the next day to fix.. sorry to hear your problem..
I'm no expert by any stretch but the sealing ring that's missing is in the place where you'd expect to see it removed if dual feeding it. The one shown below looks different than yours (yours has two rings close together at the 'bottom'). This could be just a design change made during the run of TH350 transmissions for all I know.
The photo below is from Jakeshoe's article on rebuilding the TH350. The article can be seen HERE. It shows the ring that's removed when doing the mods to dual feed. ![]() As for the rest of it, there is some severe wear going on, especially if the shaft wore that much in that short of a time, more likely it was worn when it was installed. Looks like a lack of lubrication for whatever reason caused much of the wear in that short of a time, though. |
never heard of 'em. Sorry for your bad luck. Definitely not who I would have recommended obviously (Lonnie, JakeShoe, CKPerf, RPM, Finishline, Art Carr). Hell even TCI or Jasper would have answered their phone at least.
Make sure you post up the rebuild, and who did it and the final results. |
| Warning Ripoff. Fraud. Warning | 71gtx | Hotrodders' Lounge | 22 | 09-09-2011 10:09 PM |
| Barrett Jackson, ***? | crystalbluevib | Hotrodders' Lounge | 8 | 01-01-2010 08:27 PM |
| Performance Heads add in Chevy Hi Performance | sdimpala64 | Engine | 1 | 04-29-2008 08:59 AM |
| Michael Jackson | malc | Hotrodders' Lounge | 27 | 06-15-2005 04:38 PM |
| Barrett-Jackson | bonuts | Hotrodders' Lounge | 9 | 01-18-2003 11:32 AM |
