warning lights stay on when key is not in ignition
this is happening in my 1995 suburban
When I hook up the negative battery cable my warning lights come on key off. when i start the engine it does not turn off unless i remove coil wire. I replaced the ignition switch and ended up with the same results I just put in a new engine and all wires look fine what could cause this? |
Thanks for replying.
I pulled the horn fuse and the problem went away. I will have to find where the horn feed is shorting out. It's not the horn cause I disconnected it and still had the lights on. Only pulling the horn fuse fixed the problem. |
Could be a BCM problem.
Might be a good Idea to scan the system for any codes. That may lead you to a diagnosis Also, first, check to be sure horn relay is plugged in , correctly. They can plug in backwards, and allways keep the circuit alive, and backfeed into other things.
Fact is stranger than Fiction |
| The Following User Says Thank You to LATECH For This Useful Post: | ||
satdiver1 (11-10-2012) | ||
Another items to check is the alternator. There should be a diode (allows current of flow only one way) in the 12 volt line to prevent back feed, since the alternator always has battery power. However, this diode should have been installed in the stock wiring.
Bruce |
| Brake lights stay on | Techguy_2000 | Electrical | 3 | 10-16-2007 08:43 PM |
| brake lights stay on.... | jmtw | Electrical | 6 | 03-06-2005 07:48 AM |
| starter & ignition stay engaged with key off | 67cuda | Hotrodders' Lounge | 7 | 09-06-2004 10:20 AM |
| starter & ignition stay engaged with key off | 67cuda | Electrical | 0 | 09-06-2004 09:31 AM |
| Warning Lights | bonuts | Electrical | 3 | 10-28-2003 04:42 PM |
