it looks alright i guess i cant really see.
lots of shops can't fix hoods for crap unless they get a sharp pick hammer to it, take out the arch, and load it up with mud. It's a shame. Or in other cases they'll say it's the supports pulling it down here and there and there's nothing you can do about it...yeah right! I've seen hoods come out of REPUTABLE shops where everything on the car is perfect except slight imperfections on the hood. the key is to give it special attention. If you want to know how good they are ask them how they'd handle your hood.
The right way to fix a hood is in most cases separating the adhesion between the supports and outer skin, metal work, then shrink it tight enought to block with a shrinking disk, then re-adhere it to the supports before filling....thing is, most guys don't pay for that so I just get out the pick hammer and start pecking-lol |
Make sure the frame is still glued to the hood skin
around all four openings. If the frame has separated, then the hood skin might warp. |
Brian |
No body knows whats under there or if it was done right, so its gotta go. First get it down to the metal THEN decide what to do with the hood But unless its something very rare I'd find another one ,that one is something I'd pass on if I was looking for one. Go to lowes and buy a gallon of Jasco paint stripper and spend 4hrs stripping it before you bring it to the shop That'll save you 200.00 right from the start. 4hrs stripping + 10hrs bodywork + 10 hrs blocking prep and paint = 24 hrs labor at 50,00 per hr (min) =2400,00 ...Thats just for the hood and that doesnt inc. underneath or buffing. So what do you end up with ? a nice looking hood full of bondo......Find another hood .... |
DBM is right on in that replacing it if it is too bad may be the best choice and much cheaper than having it fixed or leaving it up to a bodyshop that doesn't know how to repair something like this. Replacing panels like that can be a real chore, or they are relatively easy to find and it's the best way to go, it is tough call as we may not know the car you are working on that well.
I know a stock hood on a Chevelle of the sixties is easy as pie to find because everyone replaces them with repro SS hoods. Personally, I rather have a nice original flat hood than a Chinese repro but that's me. Yep, getting it to bare metal and getting a real good look at it is the way to go, and use a paint stripper as DBM suggested, DO NOT try to sand or God forbid grind it off! You want a warped hood, that will do it if done anywhere near incorrectly. Here is a little "Basics of Basics" on something like that hood. (click here) Brian |
So my options are 1: find a new hood
2: strip the hood and see what's underneath 3: have faith in a body shop Doing some research I found 2 company's that make 69 Chevelle flat good. Unlimited products and us body source. It looks like according to the picture that it has no rear grills. Also have you heard of these companies?? |
Bring it to a shop first, repro sheet metal is the LAST resort period. I don't know those companies but it is pretty much a moot point being most all repro sheet metal comes from the same couple of sources.
Brian |
Thats not even an SS hood.......should be able to find one easy......Get another hood
Ontario Rodders |
Forget about a new hood get a good used one for 100- 200.00 it'll be 10 X better AND OEM...theres a bunch of them around here I even saw a few at a U pull it ,all their hoods are 50.00.....hey I found a 48 plymouth biz coupe deck lid so this is a cake walk.....try this site start with salvage yards close to you and expand your search http://www.car-part.com/
| warped....., so is my tailgate | cmc-10 | Body - Exterior | 16 | 01-29-2012 06:22 AM |
| warped heads | theg | Engine | 9 | 01-17-2012 08:43 PM |
| Warped panel HELP | jesuscowboy | Body - Exterior | 1 | 02-04-2009 11:01 AM |
| warped rotors. | stickysilverbird | Suspension - Brakes - Steering | 5 | 12-29-2007 09:45 AM |
| Hood is Warped from Sandblasting | 55paneltrk. | Body - Exterior | 20 | 03-30-2006 03:57 PM |
