washed 396?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2005, 09:39 PM
pi71's Avatar
washed 396??
Hey guys i just bought a 396 engine from a guy that rebuilt the engine. forged pistons,comp cam 280, roller rockers, anyways He said that when he started the motor to break it in it shot gas out the carb. (alot) he finally got it running but he said he couldnt get it to idle or adjust the valves.. well it looks like some of the cam (still in engine) is worn a little.. he said he drove it around the block but it was running rough... he had another guy tell him he "washed" the motor so he pulled it out and bought a crate motor.. Could i get by with just replacing the cam and running it? He sold me the motor for 200 bucks with a new comp cam to put in and 750 holley. (the guy has money and just wanted it out of his garage) can this be fixed? how bad is a washed engine?
Old 09-10-2005, 10:03 PM
71 c-10's Avatar
just a kid and his truck
your safest bet is to porable tear down the entire motor and check it over, maybe even send the block to the machine shop. totaly inspecting the whole motor would be the only way i would put it in something, if the cam whiped there is the poisibilty of metal througout the motor..
Old 09-10-2005, 10:13 PM
347mustang's Avatar
most diffenly...tear it down..inspect it all find the problem if any...just guessing will make it worse...even new bearing and gaskets are around 150.00....
Old 09-10-2005, 10:57 PM
DoubleVision's Avatar
The cam being "worn a little" doesn`t say much, The cam will have some wear, as all flat tappet cams do, they have to wear in, this is part of the break in process. The cylinders being washed can be a problem as it can cause accelerated ring wear. the engine running rough could have been for many reasons, and those reasons may or may not have anything to do with the cam or the rings. If the engine isn`t even broke in good and it sounds like it`s not, then I would drain the oil and screen it to see if there`s any excessive metal in it, I would also cut the filter to check it for the same, if it looked okay and metal was at a minimum, I would just do a oil and filter change, tune it properly and run it.
Old 09-10-2005, 11:02 PM
pi71's Avatar
HEY doublevision, thats what i thought i really have nothing to lose on this motor.. what is normal cam wear(visually) without removing the cam. He had allready drained the oil and removed filter when i got it .. the oil pan is still on though..
Old 09-13-2005, 01:26 PM
pi71's Avatar
update*** i pulled out the camshaft and it has some major flat lobes.. 3 or 4 of the lifters were caved in,, i pulled off the oil pan and everything looks good including oil screen there is some small metal grey matter in the oil pan..Im gonna replace the camshaft and go with it. after a good cleaning.. by the way the rocker nuts were almost impossible to get off ... they were that tight...
Old 09-13-2005, 03:21 PM
"Rocker Bolts"???
....If you mean rocker studs, there's no reason to take them out. If you did, then they need to be cleaned and put back in with locktite and torqued. I don't know the torque spec on rocker studs.
....If you mean rocker nuts, then that may have been the reason for the rough running and the flat cam...Rockers adjusted too tight.
JA
Old 09-13-2005, 05:22 PM
steve t's Avatar
ex biker, now hotrodder
run it,check oil pressure, dont let it run hot,
Old 09-13-2005, 10:42 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
If you have the oil filter that was on the engine you should cut it open and take a look at it. If the cam and lifters were worn that bad then the filter is probably full of shavings. If the shavings are small enough then they will pass right through the pickup screen. You should take a look at the bearings too, the shavings can/will embed themsevles in the bearings. Make sure they are still in good shape. Not to mention the shavings passing through the oil pump...
1969 396 69 chevelle SS Engine 4 09-13-2005 01:29 PM
396 vs 454 69 chevelle SS Engine 13 06-26-2003 09:00 PM
396 Again sboston Hotrodders' Lounge 4 04-24-2003 07:03 AM
396 sboston Hotrodders' Lounge 3 04-23-2003 05:17 PM
454 turned 396 swap crash Engine 3 04-06-2002 10:02 AM
