washed filler areas per instructions... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2006, 06:15 PM
Hi all!
Before I got the word to NOT wash filler areas I did per the instructions on the Evercoat Rage Xtreme can. I only washed small areas and dried them right after. Do I need to take any corrective action?
Thanks, Walt
Old 04-09-2006, 08:23 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
let them dry out good and you will be fine.. Define wash for me though if you dont mind.. did you use soap and water and a sponge or was it a damp cloth wet.. was it wax and grease remover.. tell me what we are exactly talking about
Old 04-10-2006, 07:39 AM
HI,
I used hot water and a sponge.
Thanks for the reply!
Walt
Old 04-10-2006, 01:30 PM
BondoKing's Avatar
KING OF BONDO
Then let it dry well as i said before and you shold be fine.. you could put it in the sun for a few hours or put lights on it for a few hours.. It should be fine.. its not like you hosed with the water hose
The most common mistakes made by the newbe working with plastic filler. MARTINSR Body - Exterior 7 02-14-2006 11:21 PM
body filler esahlin Body - Exterior 18 02-12-2006 03:59 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 01:22 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 05:30 PM
Body Filler do's & don'ts Ron M Body - Exterior 2 09-07-2004 06:00 AM
