Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - waste management
Old 07-16-2003, 03:26 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
maybe, depending on cam, and carb size as the rest of your combo. to make it more responsive you could go with dual 390 holley`s, a open plane intake is drawing off the entire mass under the carb, so fewer total cfm is acceptable. as i said, depending on the rest of the combo will dictate the rest.
