waste management - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2003, 12:09 AM
waste management
Is it possible to get the bog out of a two four high rise manifold, to make it street drivable, or do I give it to Waste Management?
Old 07-16-2003, 03:26 AM
DoubleVision's Avatar
maybe, depending on cam, and carb size as the rest of your combo. to make it more responsive you could go with dual 390 holley`s, a open plane intake is drawing off the entire mass under the carb, so fewer total cfm is acceptable. as i said, depending on the rest of the combo will dictate the rest.
Old 07-16-2003, 09:18 AM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
I would go with vacuum secondaries also. Sorry if 390's only come in vacuums, I've never seen one...
Old 07-16-2003, 09:51 AM
It's on a 454, cam is 286 intake, 296 exhaust. I think it would be considered a 3/4, MSD ignition, rest is mostly stock, 450 Hollys.
Old 07-16-2003, 11:38 AM
Hollywooding's Avatar
Canknuckle Head
isnt that a bit much on the duration? most of those kinda cams are for 2000 -6500 apps i thought?
that's where i would look.
Hollywooding
Hollywooding :cool:
Old 07-16-2003, 12:40 PM
This is what was in when I got it. Where should I be?
Old 07-16-2003, 01:50 PM
Canknuckle Head
I'm not a cam afficionado or any cam guy. However for a street app. most don't go past 280 to maintain streetability. After all your not running at full throttle all the time. comp cams makes a pretty good listing of different styles of cam. even switching to one of those 280's would probly help you out.
That is of course provided you have eliminated all of the obvious first (carb, timing, fuel filter, wires, plugs, etc.).
My two cents
Hollywooding
HTH
Hollywooding :cool:
Old 07-17-2003, 10:24 PM
I know zip about cams........two cents is a lot when your broke. Thanks for info.
