-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   waste oil lubricant (http://www.hotrodders.com/forum/waste-oil-lubricant-52846.html)
cboy 11-27-2004 11:37 AM
waste oil lubricant
Speaking of waste oil, would there be a problem using waste oil as the lubricant for drill press and band saw work?
OneMoreTime 11-27-2004 11:51 AM
Nope
I thin it a bit with paint thinner so it drips good is all..
OMT
julmer 11-27-2004 07:10 PM
Only problem I know of is that you will get your pieces a bit dirty. Sure beats the cost of special cutting fluid. I'd avoid it for tap and die stuff where clean is more important.
