waste oil lubricant - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2004, 11:37 AM
cboy's Avatar
Last journal entry: Finished
waste oil lubricant
Speaking of waste oil, would there be a problem using waste oil as the lubricant for drill press and band saw work?
Always learning...and sharing what I've learned.
Old 11-27-2004, 11:51 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Nope
I thin it a bit with paint thinner so it drips good is all..
OMT
Old 11-27-2004, 07:10 PM
Old enough to know better
Only problem I know of is that you will get your pieces a bit dirty. Sure beats the cost of special cutting fluid. I'd avoid it for tap and die stuff where clean is more important.
