Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - water in compressed air, what do i need?
Old 02-07-2010, 10:51 PM
matt167 matt167 is offline
Wiki Edits: 31
I had the same problem.. my solution was to run a pipe right to the celing and back down ( about 6' ) to a water seperator.. now all the water flows down into the compressor.. drain it out once a day and it's good, never any water at the paint gun and the compressor gets pretty hot.. draining the regulator on the compressor, I had to put a small water seperator right on the compressor because the water would back trace right thru the regulator.. now the trap catches it and dumps it outside because it's self draining ( closes with preassure, otherwise open ) and I ran a line out the wall
