Water In Compressor Pump - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-20-2010, 10:24 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i dont remeber the brand, but some of our trucks use the older style air dryers and some have the newer spin-on type filter, dryer
  #17 (permalink)
Old 12-20-2010, 10:44 AM
Originally Posted by 69lm69gp
I called Eaton. They recommend cleaning out the sludge with mineral spirits and using heat tape to warm up the crankcase. They also told me where to look for the vent.
Unless your compressor was just worn out or had other mechanical problems causing excessive blow-by, neither of which is likely the culprit, then the combination of cooler temperatures and restricted crankcase ventilation is the likely cause. I have seen this several times and it usually is a very simple fix that costs nothing except a bit of time spent on maintenance.
  #18 (permalink)
Old 12-21-2010, 03:43 AM
deadbodyman's Avatar
Wiki Edits: 11
I finally changed my comp oil yesterday.... all these threads got me to worrying about it...glad I did ,checked all the fittings with soapy water and found a few leaks ,some of them were pretty bad and I finally fixed my drain pitcock,must have had two gallons of water in the tank.I was a little surprised ,it worked fine on my end of the hose..last year I found out your oil needed regular changing and I've been meaning to change it ever since.
  #19 (permalink)
Old 12-21-2010, 06:59 AM
Wiki Edits: 27
check valve leak?
could the check valve have a slow leak allowing moist air from the lines and tank reverse back into the compressor and condense?. How good does the system hold air after you shut it down?
  #20 (permalink)
Old 12-21-2010, 07:20 AM
& matts38chev
i bought a new quart of non detergent oil last year but i didnt get around changing the oil.
maybee today, i took the rest of the year off to clean up the garage and see if i can find my car out there.
  #21 (permalink)
Old 12-21-2010, 07:27 AM
sqzbox's Avatar
My pipes are my music
Your system from the comp. out must be darn good. I know you body guy's are terrified of fish eye's which can be contributed to water in the system. Every place I've ever worked that had a comp. always had to be drained daily. I'm surprised you haven't had problems already.
  #22 (permalink)
Old 12-21-2010, 07:48 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I bought and installed a moisture ejector from HF last year on my air tank so that everytime the compressor cycles it spits out the water from the bottom of the tank . I have to lay on the floor to manually drain the verical 60 gal. tank so this was a good upgrade .
  #23 (permalink)
Old 12-21-2010, 08:11 PM
& matts38chev
i use these cheap corded big truck air tank drains on the compressor tank so i dont have to stand on my head.
and on the drains on the piping in the corners i cant get to
  #24 (permalink)
Old 12-21-2010, 08:19 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Hey , I have never seen one of those before . Where did you buy it ? Our trucks at the mine were 240 ton payload (830,000 lb GVW) and had automatic moisture ejectors on the wet tank.
  #25 (permalink)
Old 12-21-2010, 08:52 PM
& matts38chev
i got them at the local kenworth dealer
i just got the pic off of ebay i think it was like $11.oo
  #26 (permalink)
Old 12-21-2010, 08:56 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Thanks . I will check and see if my automatic ejector is keeping my air tank drained and if not I will likely install one of those instead .
  #27 (permalink)
Old 12-21-2010, 09:06 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Cable operated drain valve
I found this with a google search : http://www.rydersafetyservices.com/r...E98D4D61F07760
  #28 (permalink)
Old 12-21-2010, 09:18 PM
& matts38chev
bingo
  #29 (permalink)
Old 12-22-2010, 08:03 AM
Were those trucks Dressers or Cats? We had some serious problems with the air systems on the Dressers but I suppose I am about to get off the topic here, sent you a PM.
  #30 (permalink)
Old 12-22-2010, 08:09 AM
sqzbox's Avatar
Yeah, but look at all the stuff you found under there that you thought was gone forever.
Water Problem with Air Compressor 71gtx Garage - Tools 46 06-04-2007 12:51 AM
350 Chev head gasket water holes too small? rlmfire Engine 7 04-14-2007 08:11 PM
Electric water pump, what gpm? New fan? 84Z Engine 4 02-01-2007 05:30 PM
Water question-2.2 4cyl S10 Ted655 Hotrodders' Lounge 7 10-22-2002 06:23 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
