Water in the engine!!! HELP!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2002, 07:28 PM
New Member
Post Water in the engine!!! HELP!!
I recently bought a 89 chevy blazer with a tbi 350 stock engine. Both head gaskets were blown. What are the chances of the heads being good? I also tore the top end down and there is water in the oil. What is a good choice to clean the engine with? Is there anything else I should do?
thanks,
John
Old 11-05-2002, 07:35 PM
Post
Have the heads checked just to make sure
Old 11-05-2002, 07:37 PM
New Member
Post
Do these iron heads usually warp or crack because of a blown head gasket? Is it common?
Old 11-05-2002, 07:58 PM
Post
Some late model heads had problems with cracking. If the truck overheated, this could cause warppage.
Was the water from the heads being removed? Water could have come from the head gaskets. Usually you won't have a problem with the block unless it really got hot or froze from very low temperature.
What are you reffering to when ask what is a good choice to clean the engine with? Are you reffering to the external parts of the engine or the internal? I'm assuming the internal parts. The cooling system, you can use dawn dish washing liquid make sure all the suds are flushed completely. The lube system, you should have much problems usually the water will be carried to the oil pan, water is heavier than oil so it will stay on bottom of the pan.
