If it was burning coolant, you would see and smell it in the exhaust. (At least you surely wood if you're using a 50/50 glycol / water mix as we do here in Canada.
Thinking about it... TN (and all of S.E. US) has been in the news for having unusually cold weather and precipitation this winter. The damper and colder it is, the more visible and steamy the exhaust. Headers / Dual exhaust gives you a whole lot of pipe area to acccumulate moisture. You should also notice that the appearance of steam and droplets of water should diminish somewhat after you get the exhaust system warmed up and dried out. That isn't going to happen idling around town. Perhaps a 1/2 hour drive on the highway might dry it out? Here's another thought. Put a large sheet of cardboard under the engine bay. and inspect the drippings if any. If you see green (assuming old-syle glycol antifreeze) it will give you a fairly good indication of where to look for the leak. |
ok the car does not smoke at all no matter how long i drive still puts out alot of water no leaks from any where the over flow which is a tank not straight out on the ground and i like to run it half full and you guys keep saying becouse it winter it year round 3-5 feet of water spray summer or winter i buy 100% green coolant and add water to the coolant i have a 190 thermostat new radiator cap still no leaks from any where
| Water coming out of exhaust | 350chevypower | Engine | 2 | 09-10-2010 01:18 PM |
| Gas? Water maybe? Possible exhaust problem | 65Stanger | Engine | 22 | 04-08-2006 01:51 AM |
| water in exhaust | husker_du_67 | Engine | 4 | 01-13-2006 07:39 PM |
| Well water (iron in water) Automotive paint | 1931 steve | Body - Exterior | 11 | 07-14-2005 09:29 AM |
| power steering from long water pump to short water pump | kellyem | Suspension - Brakes - Steering | 7 | 02-22-2004 07:22 PM |
