Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - water filters/traps for air compressors
Old 12-28-2005, 12:10 PM
oldred oldred is offline
Water trap/Regulator- is what you need here, use a filter after that if needed. If you have been reading up on this then you are probably aware that the water trap will need to be located some distance from the compressor(25 ft or more) or use some other method of cooling the air before it enters the trap otherwise it will not do much good. Also that compressor seems much too small to properly operate the HVLP gun since they usually need at least 12-15 CFM and that would be cutting it close.
