Water flow - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2006, 05:42 AM
wavy's Avatar
Last journal entry: Progress on Willys
Water flow
On a 302 ford with a standard flow water pump, which way does the coolant flow to the heater? From the water pump through the heater to the block or the opposite way?
Old 11-21-2006, 05:42 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Should flow from the block to the core, then to the pump. When in doubt remember that on standard-flow engines (not pumps since even reverse rotation pumps still flow the coolant in the same direction) coolant flow goes pump, engine, stat, upper hose, rad, lower hose, pump. So the water in the heads/manifold is the last thing before the stat. Since the stat always makes a restriction, water is sourced between the pump and stat to supply the core, and then it returns between the stat and pump (or in the pump itself.)
That way the water is always sourced before the restriction and returned after it to ensure flow through the core
Old 12-11-2006, 01:00 PM
LordMaximo's Avatar
Last journal entry: Painting
Water flows from the stat to the radiator down to the water pump, and is circulated trough the engine until the stat opens again and dumps back into the top of the radiator.
water pump problem rakundig Engine 15 08-10-2007 09:15 AM
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 08:26 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
Water question-2.2 4cyl S10 Ted655 Hotrodders' Lounge 7 10-22-2002 06:23 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
