You can buy gasoline with alcohol already in it. E-10 gasoline has 10% ethanol.
How much water got in the tank? A quart? a cup? A few ounces? If a few ounces, the next fill up will probably dissolve the water in the alcohol, the alcohol will dissolve in the gas, and run through the engine. When the water is going through the engine, the O2 sensor will tell the computer the air to fuel ratio is a bit off, and the engine will just run a bit more fuel to compensate for the water. It might even remove some built up carbon from the combustion chambers. If you have a quart of water in there, the alcohol will dissolve in the water, and the water will not dissolve in the gas. Water being denser than gasoline, will settle in the lowest part of the tank, and if that is where the fuel pickup is, your fuel pump will send some water, with a little bit of alcohol in it, in to the engine. Your engine will not run on this. So, how much water? |
just dump some HEET F.I. cleaner in there the next couple of tanks and it will be fine
you can buy it in a 4 pack may run a little rich/rough for a while but it will clean out or you can take the tank down
Heet may have been one of the additives I was thinking about from the carburetor days but I just read up on it and apparently it is safe for FI systems so I will give that a try.
HEET should work. We used to race our modified ATV's through mud pits basically water over the seat the whole time. Of course they were snorkeled, but water always found a way to get some in the tank. It was fuel injected! ever time we rode I put some heet in the tank. It used to stall on me sometimes from the water getting in, so then we would have to syphon the tank. After trying the heet it never died again. Of coarse these were abused atv's, but should give same results.
Just dump in 3 or 4 cans of drygas and it should take care of it.
Artificial Intelligence is no match for Natural Stupidity Chet |
Drygas is the other additive I was thinking about but again being alcohol based I was worried about what it might do to the FI system. I did a bit of research and it seems that maybe it can do harm (Heet also) but only if over used so I added the Heet at the low end rate. I have driven it about 25 miles today and the check engine light came back on but the engine has not been running rough this time so I will give it a couple of days to see what happens and then erase the code to turn off the light. |
Is there cheap pump that you can buy to pump out gas from tank
| Recent General Rodding Tech posts with photos |
| Is this Gas Tank neck bad? Tank? Clean it? Leave it? | gotmud | Engine | 2 | 07-06-2011 12:43 PM |
| Well water (iron in water) Automotive paint | 1931 steve | Body - Exterior | 11 | 07-14-2005 09:29 AM |
| Air Compressor Water Traps & Tank Reservoir Drains | ultgar | Garage - Tools | 1 | 01-26-2005 12:01 PM |
| how can i make a water heater into a a.c. tank? | 68MUSTANGhardtop | Garage - Tools | 12 | 05-09-2003 08:13 PM |
| Need Tank Sender for Custom Gas Tank.... | bg | Engine | 3 | 11-05-2002 05:13 PM |
