My car takes a long time to heat up, especially in the winter. I drive about 3 miles to work. A mix of city and freeway taking usually about 15 minutes. About halfway there the coolant warms up enough to produce heat. I have a '64 Nova wagon with a 194 6. Would changing the thermostat to a higher temp unit help?
Probably not that much. Make sure it's closing completely. Try closing off the bypass or installing a electric fan to minumize airflow through the core while warming up.
Geez, you're lucky you don't live where it gets cold.... :thumbup:
Thermostats only control the minimum operating temperature. Until they open the water just recirculates until it reaches the design temperature.
When it is cold, pop the radiator cap and start the engine. See if there is any water circulating when the thermostat is suppose to be closed. Should not be any movement. You might install a NEW 195* thermostat in case the old one partially opens at too low of a temperature, and then hangs at that setting until later, then goes to full open. Probably it will not help.
3 miles/ 15 minutes in freezing weather is problematic.
Heater cores are little radiators. When you have the heater on and blowing full blast the water is being cooled by the heater, so the engine takes even longer to warm up. Example = Lincoln TownCar the heater will not blow until the water warms to a 120*. No need to blow icy air at your feet.
I would suggest to you that "warming it up" for 15 minutes with the heater OFF, before you leave is probably the only way you will get the heat that you desire.
You could try using a coolant heater that installs in the heater hose and keeps the coolant at 50* all the time when it is plugged into the wall. That is.... if your heater is the full flow variety that does not have a water shut off valve when the heater is OFF.
12 hours a day plugged-in will cost you about 90 cents a day for electricity.
I remember when my buddy had a gasoline fired aircraft heater in his old Corvair....... instant full heat !!!!!!! That was nice at below zero.
I have no idea what's in there now. I bought the car like that. I have thought of doing what truckers do and restrict some of the airflow through the radiator by partially covering it up. This is also a new radiator that I've been using only since October.
As we got into the 20s last night---Brr---my blood is thinning
I am in the habit of warming the car before leaving---if below 40* out.
10 minutes and still no warm air-----2005 Ranger----
will warm after about 2miles + 10 min idle
Neither one of the T-Birds will blow warm until after 3-4 miles
These cars have Auto-temp-----won't even blow air til they warm up.
If you are only going 3 miles in 15 minutes---with a manual trans., you are not loading the engine at lights--longer to warm up.
yep, if you want heat, you could buy a oil heater and put it on every night. also allow 5 minuites to warm up b4 driving, specially on older cars where chokes and carbs are depended on.
Well, I have a Maverick with a 250, 3 speed, bout the same set up as you. These cars never had a heater worth anything. Early Mustangs were the same too. I used a piece of card board and covered 1/2 of the direct air flow. It did help, it didnt set you on fire but it was warm. I disagree, when you partially cover the front of your radiator, you limit the amount of airflow the fan is pulling through it. Keep an eye on the temp gauge, in that short distance, you might could cover over half of the radiator. I dont know how cold it gets where you are. Are you running 50/50 in coolant mixture. If you run pure antifreeze, it takes just a little longer to warm up. I live in Ga, so the temps here dont drop and stay in the - F as ya'll do. We might get down in the teens for a short bit, mostly we get down to around 20 to 25deg. But for us thats pretty cold. All in what you are used too I guess. I have taken my fan off and drove all winter with no trouble at all. But it was a work thing, before I went any kind of long distance, fan was in the trunk, took 3 minutes to stick back on. Though not recommended, it did help. As a matter of fact I parked the car almost 10 years ago, fan is in the trunk now.
Please help me understand. I need to learn. :welcome: I grew up/ 20 years where it got -30* BELOW ZERO.
How could blocking the air flow through the radiator make the engine warm up faster IF THE THERMOSTAT IS NOT CIRCULATING WATER THROUGH THE RADIATOR anyway ??????
Sufficiently restricting the airflow will make the coolant hotter than the thermostat's open-temperature AFTER the engine warms up.
In such case, you just need a higher temperature thermostat.
I lost the choke when I put the split exhaust manifolds on. My last car didn't need the choke either. It's usually in the 40s in the mornings but lately it's been in the upper 20s low 30s. A little unusual here.
I realize that I didn't use the term "back flush", but when flushing a system there is only one way to do it properly.
If the heater core cannot take it then it's time to replace it.
3 miles is not a long distance to go, but 15 minutes should warm up an engine in most cases. My thought is basically to first ensure that the system is clean and then to make sure it's functioning properly.
Cardboard in front of the radiator only helps when the radiator is functioning so well that it keeps the coolant too cold therefore not retaining enough heat to transfer through the heater system...it will not help in this case.
Ensuring a clean and properly functioning system may as he doesn't see temps this cool too often.
Also, starting the car a few minutes earlier would probably help.
Yes, we've been hearing about your freezing temps, and the effect on the citrus crops, which affects us all.
This cold weather is due to a huge Hi in the arctic, pushing all that cold air south.
It was -30°C (-20°F) here in Alberta a few days ago, but has now warmed back up to right around the freezing mark. (0°C or 32° F) which is about the same as El Paso!!!
Sounds like you don't have a thermostat ... remove the thermostat housing (attaches the upper rad hose to the engine) and have a look. Make sure you have a new gasket first, or you'll be hitch-hiking to the parts store. :mwink:
<Teasing now>
Dress in layers, put on a touque and scarf, and your "long-john" thermal underwear ... and hang on ... this "cold" weather won't last.
I usually laugh at the people who complain "it's too cold" when it's in the 50s. What we have here in the Bay Area is nothing compared to other parts of the country. Even at work I have to wear my coat in the shipping area. Even with the doors shut and the heater going. I never had to do that before. I must be getting old.
This usually helped after the thermostat opened, or the water reached operating temp. The cardboard was for trveling at normal speeds down the highway. His problem could be no thermostat at all, restricted/ kinked hose, collapsed fitting, plugged core. Could be a number of things, the cardboard worked for us. Still does for me. It was just a suggestion to try.
congrats on solving the problem (new thermostat)....don'tcha' love it when $10 is the fix!
I'd be looking for some new doors/windows weatherstripping....50* and 90% humidity and a 65mph draft in the car = friggin refrigerator....they aren't real expensive or difficult to install.....to do what you can to keep the heat in the car
"el cheapo" fast and easy weatherstrip fix, thin, "closed cell" door foam/self adhesive weatherstrip from Lowes on top of the existing to get back an air seal.....wipe down the old with lacquer thinner, paint the new foam rattle can flat black before installed....I mentioned this cause I don't know if a new rear door seal is available for your car....
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
