Water injection for carburetors - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2012, 08:02 AM
can somebody post a picture of their system like this ? im slightly confused on the pick up lines. i have a gallon jug with 2 hoses sticking out of it, one with a air stone and the other is waiting to go in a vacuum line ???? i just dont understand where the pick up line goes, i do believe the air stone is just a vent leading outside the lid, right ?
and i didnt wanna bring back a 2 year old thread, didnt know if people would hate me =[ haha
Old 07-16-2012, 08:13 AM
Wiki Edits: 27
vapor injection
They were popular in the 70's when new cars would diesel, cough, sputter, etc. My nephew had one and I think he used a hobbs switch so to only use the system after the engine warmed up. and you should not have trouble with the system freezing up in the winter. one hose vented to outside air and the other to the intake. Hobbs switches are use for water injections on some turbo systems, I don't know how he had his hooked up Mabe get elect from engine temp switch ?
The Following User Says Thank You to timothale For This Useful Post:
LEROYDOZOIS (07-16-2012)
Old 07-16-2012, 08:24 AM
mine is just the siphoning setup, not the actual injection setup... thats what im kinda confused on, am i picking up water vapor from the bubbler or actual water ?
just trying to figure it out =P
How fast is fast enough?
This way you get water injection when you least want it, and don't get it when you do... It's not entirely wrong, but its the opposite of correct.
You want less water at high vacuum and more with less vacuum, it'll also need some way to be adjusted for RPM or air volume.
Old 07-16-2012, 11:14 AM
S10 Racer's Avatar
http://www.warsprints.com
Back in the 70's & 80's the company I worked for used these on all their mobile welding trucks and I built one of my own.
Materials:
A jug or bottle with a screw on cap.
Fish Tank Aerator Stone
Vacuum Hose
Small Adjustable Valve
You run two vacuum hoses through the lid. One vacuum hose ends close to the bottom side of the lid where it is always out of the water, this line runs directly to a vaccum source on the carb. The fish tank aerator stone connects to the end of the second vacuum hose and sets in the water at the bottom of the jug/jar. The valve connects to the other end of this hose for adjusting the incoming vacuum.
When the engine is started, it pulls vacuum through the jar. As you adjust the valve, the incoming air pulled through the fish tank stone aerates the water and makes a mist which is pulled into the engine.
The Following 2 Users Say Thank You to S10 Racer For This Useful Post:
AutoGear (07-16-2012), LEROYDOZOIS (07-16-2012)
Old 07-16-2012, 12:55 PM
Materials:
Vacuum Hose
what improvements have you noticed with this ? more mpg? cooler running temps? both? thankyou for the details, i assumed correctly i believe, just didnt wanna mess things up =p
Old 07-16-2012, 12:58 PM
on the 12 mile trip to work today the truck stayed at the 14.5-15.2 afr range majority of the way here,(low load = light foot ) so if my crusing mode becomes more efficient id be just as happy as power mode becomming a little more efficient, for the time being i think this ill work outpretty well.
Old 07-16-2012, 01:28 PM
smh. You can lead a horse to water...
Old 07-16-2012, 01:39 PM
was this comment ment towards my afr readings or my judgement of the water injection idea?
Old 07-16-2012, 02:38 PM
your misunderstanding of water injection.
Old 07-16-2012, 02:56 PM
Materials:
Vacuum Hose
how do you adjust the valve to the vacuum ratio ? did you use a guide line of some sort ?
Old 08-03-2012, 07:34 PM
S10 Racer's Avatar
It's basically a set point and you leave it there regardless of vacuum. With the engine running you open the valve to a point where the liquid will bubble. This causes a mist to develop which is then sucked in by the vacuum. IIRC, it did help mileage some. Back in those days though gasoline was less than a buck a gallon so it was'nt a big concern about the mileage. It helped keep the pistons and valves free from carbon buildup which helped in a lot of areas. If you build one, let us know what you think about it.
Old 08-03-2012, 08:02 PM
u can use a windshield washer pump hooked upto a hobbs switch or rpm window switch, this type of setup is more for wot type stuff though or say when towing a heavy load, or going up a steep incline
the problem with using a washer pump is they dont make a lot of presure so u cant use a real meth injection nozzle to get a real atomized mist.
most nozzles require atleast 50 psi of presure, but u can play with some nozzles to find one that will work well with the washer pump being carbed it will still atomize when it gets into the hot intake manifold. but u dont want to be spraying a stream of water/methanol in there u still want it to mist
Old 08-03-2012, 08:05 PM
vinniekq2's Avatar
experiment with the valve so that the water lasts the same amount of time as a tank of fuel.You can use an aquarium valve and hoses for this system.
Old 08-03-2012, 08:07 PM
u can always do what i did and build urself a 1 gallon tank out of aluminum or steel and mount a fuel injection fuel pump inside it, this will produce the right presure to use a real meth injection nozzle
this type of system would work much better then what ur trying to do
old school, water injection
Water-Methanol injection N/A 434camaro Engine 0 04-10-2010 07:10 AM
Water/Alcohol Injection Blazin72 Engine 1 11-15-2005 07:35 AM
Water injection Guy Hiltz General Rodding Tech 2 11-04-2005 12:27 PM
Water injection Mikey_mike Engine 8 09-14-2003 11:35 AM
Water Injection Mertz Engine 6 11-11-2002 09:41 PM
