Water Jacket Penitrating Studs - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2007, 02:04 PM
Hey folks,
Will you give me a recomendation for gunk to seal the head studs on my 454?
Old 09-21-2007, 05:56 PM
Originally Posted by RexRat
Hey folks,
Use either Teflon plumbers tape or better yet plumbers Teflon putty, non-hardening Permatex, GE/Permatex RTV rubber, epoxy, or LocTite. Make sure the stuff goes into the threaded hole to the bottom. Putting anything on the stud's threads and screwing it in leaves it all piled up by the top.
Studs are intended to be epoxied or LocTited into the block, bolts should use a simple sealer. New bolts usually come with Teflon coated on their threads.
Remember if you're bolting down aluminum heads that a hardened washer goes between the nut or bolt-head and the cylinder head. Same goes for an aluminum manifold, a washer goes between the fastener's "head" and the aluminum. Otherwise the twisting of the fastener will carve the aluminum part.
Bogie
Old 09-21-2007, 06:42 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Permatex #2 , do not use the tape as it can plug a line .
Luv the smell of NITRO in the morning.
Old 09-22-2007, 04:28 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I use plumber's teflon putty. I have used RTV in the past with no trouble. Either one doesn't require a lot, just coat the first few threads. As it squishes off the threads it will get picked up the subsequent threads. Clean off the excess religiously because you don't want it squishing out under the head gasket.
BB Chevy Coolant Leak @ Water Pump leejoy Engine 3 07-04-2006 01:10 PM
Edelbrock Air-Gap Water Outlets syborg3D Engine 1 05-18-2006 03:22 PM
water circulation problem cboy Engine 12 04-27-2006 09:21 AM
Timing/Water Injection Mertz Engine 7 08-20-2002 07:31 AM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
