Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water Jacket Penitrating Studs
Old 09-21-2007, 05:56 PM
oldbogie oldbogie is offline
Originally Posted by RexRat
Hey folks,
Will you give me a recomendation for gunk to seal the head studs on my 454?
Use either Teflon plumbers tape or better yet plumbers Teflon putty, non-hardening Permatex, GE/Permatex RTV rubber, epoxy, or LocTite. Make sure the stuff goes into the threaded hole to the bottom. Putting anything on the stud's threads and screwing it in leaves it all piled up by the top.
Studs are intended to be epoxied or LocTited into the block, bolts should use a simple sealer. New bolts usually come with Teflon coated on their threads.
Remember if you're bolting down aluminum heads that a hardened washer goes between the nut or bolt-head and the cylinder head. Same goes for an aluminum manifold, a washer goes between the fastener's "head" and the aluminum. Otherwise the twisting of the fastener will carve the aluminum part.
Bogie
