water meth vs small nitrous shot - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2008, 10:38 AM
i looking for a solution to get my intake charge temps down with my weiand 142 i was looking at doing either a zex perimeter plate tuned down to maybe a 50 or 75 shot to run on a pressure switch set at 2 psi or so
my other option would be a snow performance kit set up similar with a pressure switch
which would be more effective, pros, cons, etc
Old 08-16-2008, 08:58 PM
coldknock's Avatar
The Snow performance kits work well. I used a denatured alcohol/water mix with my homemade injection.
Larry
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
400 small block idling problems 19nova72 Engine 15 04-16-2006 02:53 PM
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 08:26 PM
additive lowers temp in radiator,trans. and powersteering pump IHAVECHEVYPARTS Engine 4 11-21-2002 07:42 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
