Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water methanol injection for carburetor
Old 03-04-2012, 11:59 AM
Dannyringo Dannyringo is offline
Don't know if this has been covered already, but I thought that I would throw it out there for today's fuel prices seem to be going through the roof.
In Mother Earth's news back in the early 80's there were 2 articles on making a water methanol injection system for a carburetor type car. The system I use runs off the carb vacuum at the bottom of a port. I use a reed valve that you would use for making ice off the back of a refrigerator made of brass. Some 1/4" fuel line that connects to a port on the carb. The line goes back to the reed valve then to a plastic gas can that I sealed the lid with silicone. the hose only goes into the lid about 2 inches. I then drilled another hole that attaches to a vent tube, also 1/4 inch and that attaches to a piece of 1/4 copper tubing that is bent into a "J", which rests off the bottom of the container..I then drilled another hole big enough to put a funnel into to fill the container with and bought a rubber plug to seal it with.
when the reed valve is opened while the motor is idling, you can hear the bottle bubbling rapidly as the engine vacuum pulls the mist into the motor below the carb. This idea will give a increase in fuel mileage as well as steam clean the motor and fool the 87 octane gas into thinking it is 10 to 15 points higher~! Therefore NO PINGING~!
Here is an article from Mother Earth News from the early 80's after the first fuel crisis from the 70's~! Also note that in WWII Germany, as well as the U.S. used this in their Fighters...It has been said that they injected this mix into the cylinders of the Mustangs and gave them a 350hp boost for take off and also gave them 2 five minute bursts for combat with a 5 minute cool down in between...I see that it works wonders for turbo's as well as blowers~! Here is the original article:
Anybody currently using a system bought through a vendor, or home make like mine?
