Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water methanol injection for carburetor
Old 03-29-2012, 04:31 PM
Dannyringo Dannyringo is offline
Originally Posted by 1971BB427
Need to make sure you're not running rubber hoses for any of the methanol system. All the hoses that came with my kit are flexible plastic hoses and they look like new ater several years use.
One thing to remember though is that the tank is vented and the more methanol added the faster it evaporates, so if you're not driving it much you'll find it's low when you do check it.
I did pick up that plastic hose you were talking about and hooked it up to the bottle I am using....I originally used one of those air stones in the beginning and I must of used too much methanol to water..The air-stone disappeared the next time I checked it...Had to pull the bottle and rinse out all the material at the bottom of the container...That was when I decided on the new hose and using a J tube piece of copper instead of the air stone...No more problems~!
