Edelbrock kit
I have one I bought gears ago. Its a very nice system put's the water into the top of the carb.
It has a electronic control that you can adjust the water by vacuum, RPM. as to when and how much water. I have never used it but plan on putting on a dual 4 V |
Are you guys using water injection at part throttle cruising?
Water injection
I will measure the jet tomorrow and let you know.
I read this forum a lot but this is the first time I have posted If I can figure out to post pic. I will send you the manual This unit uses a ford windshield washer that has the pump in the bottom so a floor switch should work perfect. |
Water injection
I didn't get the unit down it's in the Attic of the garage but got a copy of the manual in my filing cabinet , looked at it but gave no measurement's, the jet is a tube with groves for the hose on one end the other is pointed with a jet hole on each side to
discharge into both pri. vent. If you will give me your E-mail add. or I will send you mine and I can send you a nice large copy |
so im thinking of running this in my 302 ford engine. will i have to advance my timing for sure? and also could'nt the increase in compression blow a head gasket? and anyone know where the proper vacuum line is on a general 2 barrel?
sorry I know I am asking a lot of Q's, but I'm looking to get any power/mpg gain I can!
There;s also no reason to run straight methanol. The instructions with mine said to use a water/methanol mix, and the percentage of methanol wont cause any compression issues. Your vacuum connection should be a port in the carb's base plate where your vacuum hose for distributor vacuum advance hooks to. Simply put a T in the line to hook in the system. |
It is my understanding that you do not NEED the methanol. It is there to prevent the water from freezing during the Winter months.
Yes, the methanol does deter freezing, and the more you use the less chance to freeze up. It also evaporates quicker the more you use, so putting more in just means you'll need to add more sooner. The reservoirs are not sealed, so it happens.
My system uses so little fluid that I usually find it dries out long before I use it up. My system instructions said to use premixed windshield washer fluid for the perfect mixture of water/methanol. |
Cool, sounds good. Yeah since the weather reports say it has officially never frozen where I live in socal, I think i will run all water with a couple drops of winshield wiper fluid. And what about the bubbler? do i need one if I am using straight water? and the nozzle is it a special part or generic? any links to that one...
thanks again you guys rock. |
Never heard of bubbler for this system, and nozzles are part of the kit. Mine came with several, plus ability to select the water/methanol shot depending on your engine.
Yeah I would prefer building my own I enjoy those kinds of projects. Oh ok so let me get this straight, the atomizing nozzle end that sprays faces towards the carb, and has a tube submerged in the bottle of water to supply the nozzle with water?
| Methanol injection | dedub | General Rodding Tech | 8 | 05-31-2010 09:25 PM |
| Methanol Injection Kits | lt1tyrell | Engine | 3 | 04-16-2010 11:04 AM |
| Water-Methanol injection N/A | 434camaro | Engine | 0 | 04-10-2010 07:10 AM |
| best way to run water/methanol injection with dual carbs? | darkostoj | Engine | 5 | 02-08-2008 09:08 PM |
| Methanol injection...? | Bumpstick | Engine | 5 | 07-21-2006 09:01 AM |
