-   -   Water methanol injection for carburetor (http://www.hotrodders.com/forum/water-methanol-injection-carburetor-216008.html)
Dannyringo 03-04-2012 10:59 AM
HELLO:
Don't know if this has been covered already, but I thought that I would throw it out there for today's fuel prices seem to be going through the roof.
In Mother Earth's news back in the early 80's there were 2 articles on making a water methanol injection system for a carburetor type car. The system I use runs off the carb vacuum at the bottom of a port. I use a reed valve that you would use for making ice off the back of a refrigerator made of brass. Some 1/4" fuel line that connects to a port on the carb. The line goes back to the reed valve then to a plastic gas can that I sealed the lid with silicone. the hose only goes into the lid about 2 inches. I then drilled another hole that attaches to a vent tube, also 1/4 inch and that attaches to a piece of 1/4 copper tubing that is bent into a "J", which rests off the bottom of the container..I then drilled another hole big enough to put a funnel into to fill the container with and bought a rubber plug to seal it with.
when the reed valve is opened while the motor is idling, you can hear the bottle bubbling rapidly as the engine vacuum pulls the mist into the motor below the carb. This idea will give a increase in fuel mileage as well as steam clean the motor and fool the 87 octane gas into thinking it is 10 to 15 points higher~! Therefore NO PINGING~!
Here is an article from Mother Earth News from the early 80's after the first fuel crisis from the 70's~! Also note that in WWII Germany, as well as the U.S. used this in their Fighters...It has been said that they injected this mix into the cylinders of the Mustangs and gave them a 350hp boost for take off and also gave them 2 five minute bursts for combat with a 5 minute cool down in between...I see that it works wonders for turbo's as well as blowers~! Here is the original article:
http://www.motherearthnews.com/Green...on-System.aspx
Anybody currently using a system bought through a vendor, or home make like mine?
Dannyringo 03-04-2012 11:13 AM
Here is the article that I used to build my own injection system that used vacuum port of carb. Note that the drawing shows the reed valve in line with the vacuum advance~! This is a mistake, because if you do this and turn the reed valve off, then you have no vacuum advance~!. So, all I did is run a single line to a port at the base of the carb. It works~!
http://www.motherearthnews.com/Do-It...on-System.aspx
rsfyj 03-04-2012 01:21 PM
Kool
Great thread nice info
Dannyringo 03-05-2012 10:18 AM
Now for the arguing of the disbelievers~!
I advanced my timing to 16 degrees from 8 degrees factory spec's then the carb was already leaned out, because the RV lives half the year at 7,200 ft elevation in Flagstaff, Az...Then I go down for the winters to Lake Havasu, Yuma, or Quartzite, which is about 800ft above sea level...With the carb already leaned out I did my test with the advance already done..I went from 8 miles a gallon with detonation to 16 miles a gallon running water methanol mix. The mix I use is one 12 once bottle of HEAT in the Yellow bottle to one gallon of water which is about a 33% mix(pure methanol) not the ISO-Heat which is Isopropyl or rubbing alcohol ~!
I tested this 3 different times on a full tank of 32 miles. In all cases, I went from 8 miles a gallon to 16 miles a gallon.. Then I tried it up the mountains driving from Quartzite, Az. to Lake Havasu for a total of 72 miles; Again, 16 miles a gallon...In the 2-1/2 gallon plastic kerosene jug I use for the mix, I have now filled it a second time since last November...It sips it into the vacuum port at the base of the carb.
boatbob2 03-05-2012 11:04 AM
Water Methanol..........
Hi,if you will go to 6.5 diesel.com,click on 6.5 diesel,there is a great thread on installing.testing.and conclusions of this water methanol..very good thread (thread is by private pilot.)
Dannyringo 03-05-2012 01:03 PM
I went to the site, but could not find it. If you come across it, copy and paste the link for all to see.
Thanks
boatbob2 03-05-2012 01:52 PM
water meth injection
hi,go to diesel place.com,when it opens go to 6.5 diesel engine,and click,then look for threads by private pilot (or send him an IM)
Dannyringo 03-07-2012 01:09 PM
Here is additional fuel to the fire~! No pun intended~! I lied~ PUN INTENDED~!
http://fuel-efficient-vehicles.org/
JeffB 03-08-2012 01:31 AM
Years ago J.C.Whitney sold those they were called "Vapor Injectors" and I did use them on several cars and was surprised at the results,in place of the chemical that came with them I used a combination of "Heet" and water.A crazy buddy of mine wanted to win a grudge race "back in the day" and filled his up with nitro-methane but that's another story :nono:
1971BB427 03-08-2012 10:03 AM
The high quality methanol or water injection systems worked with an electronic sensor box that monitored engine vacuum and injected the mix when engine vacuum dropped below a certain adjustable level.
I've got one on my 427 in my Camaro, and it works really well. I run regular grade gas, and no detonation at all, even with the timing advanced a bit higher than before installing the system.
My instructions said to use winshield washer fluid as it had the correct methanol/water mixture right out of the jug. I've used it for years and it really does work. Too much methanol will usually evaporate in the holding tank before it's used, so it's a waste to increase the ratio.
Dannyringo 03-28-2012 10:52 PM
too much methanol
I also noticed that if too much methanol added to my water bottle made the hose get kind of soft and mushy...So now I use one bottle of HEET in the yellow bottle to one gallon of water...Works great~!
Eventually, I am going to purchase one of the professionally manufactured ones, but for the time being, this works good enuf. Thanks~!
1971BB427 03-29-2012 08:39 AM
Need to make sure you're not running rubber hoses for any of the methanol system. All the hoses that came with my kit are flexible plastic hoses and they look like new ater several years use.
One thing to remember though is that the tank is vented and the more methanol added the faster it evaporates, so if you're not driving it much you'll find it's low when you do check it.
Dannyringo 03-29-2012 04:31 PM
I did pick up that plastic hose you were talking about and hooked it up to the bottle I am using....I originally used one of those air stones in the beginning and I must of used too much methanol to water..The air-stone disappeared the next time I checked it...Had to pull the bottle and rinse out all the material at the bottom of the container...That was when I decided on the new hose and using a J tube piece of copper instead of the air stone...No more problems~!
1971BB427 03-30-2012 08:35 AM
The instructions that came with mine suggested using windshield washer fluid, as it stated the water/ethanol mix was just about perfect. Most the time I can find it on sale for around a buck a gallon, so that's all I've ever run in mine.
SSedan64 03-30-2012 10:39 AM
2 Attachment(s)
Holley and Edelbrock used to make kits. I think Snow still makes theirs. Several other Co.s make pricey kits now.
