water and moisture in air
Hi,
I am new to your website and having picked up information about airline setup with the diagram, I am unable to open the diagram. I wonder if anyone can help. I have a REAL PROBLEM with continual water in the airline. I have 2 water traps set in line about 4' from the compressor and then going through about 50' of hose, but it has become a major disaster when I want to use the sand blast cabinet or even just simple spraying. I would welcome any advice or suggestions. Thanks |
Thanks, Oldred.
Ok...... The set up at the moment is this;;; compressor........then short rubber airline to filter 1 then in line to filter 2. then about a 15' airline, then a join to 50' airline. This then connects up to whatever tool or cabinet I am using. Clearly I have made a big **** up. I really look forward to hearing set up suggestions. Chris |
Lynch,
oldred is right on with his Post (as usual )-if you continue to have problems (after moving your Water Traps), I have had good luck with this:http://www.sjdiscounttools.com/jlmm100.html Some will call it a "Toilet Paper Filter", and indeed the element is in the shape of a roll of Tp, but I have had very good results (and absolutely no Water) using it, along with a regular Water Trap (20 ft. from Compressor)-I also use one of these: http://www.sjdiscounttools.com/mot-dd10082.html |
I am going to assume all your air line is rubber? What would be ideal is about 50' of metal air line then the separators then the rubber air hose. If it is not practical to run 50' of metal line then you can use a cooler of some sort, this can be constructed from an AC core or just some simple copper lines. The idea is to use the lines or cooler to allow the water vapor to condense as the air cools and collect on the air line walls where it can drain into collection points called "drops" BEFORE it passes through the separator, these are short pipes about one foot to 18 inches long tee'd into the line at the low points with a drain valve attached. The water will drain back into these low points then into the "drop" where it will remain out of the air flow until it can be drained. This may sound a bit confusing at first but as you start to work it out it will all become quite simple.
Here is a good example of a system set up for a small shop with restricted space. Water Separaters Also about halfway down this page will give some idea of what you will be trying to accomplish. Water in compressor lines??? There are other ways of doing this so don't be afraid to ask, we have the time and will try to help you solve this problem.
Thanks for the links.
I have checked these out and I don't think we can get these over here in the UK, I'll see if I can get the closest too them. |
Thank you very much I really appreciate your help. I will re-arrange the whole set up.
Thanks |
Ok,
Thank you for the diagrams and advice, System now 're-plumbed' in with same set up as in the link photo Thanks again Chris
| Recent Garage - Tools posts with photos |
| Custom Air Compressor Guide | goleafsgo_12 | Garage - Tools | 13 | 03-13-2012 02:10 AM |
| air lines | CARGUY | Garage - Tools | 96 | 11-16-2006 04:11 PM |
| Just finished piping the garage for compressed air... | loyter | Garage - Tools | 30 | 06-14-2006 12:41 PM |
| 2 compressors, which should i get? | toykilla | Garage - Tools | 39 | 11-13-2005 12:33 PM |
| Water in Engine | billg_69gmc | Engine | 1 | 08-24-2004 09:14 PM |
