weird
Never heard of that method. Any drive shaft I have had made came with the dial indicator sizes written down the length of the shaft for straightness and had stamp sized weights attached for balancing.
Well, I drilled a 1/4 inch hole in the driveline and drained out about 2 pints of fluid. Either Hydraulic fluid, or something like it. I was thinking, wouldn't that make the driveline act different when it was cold and when it was warm? Guess it doesn't matter, but I just thought I'd ask.
If you tried to use that d-shaft in Michigan. It would probably throw you and itself out of the car, when starting out on a -10 degree F. Morning. I've built plenty of driveshafts and never heard of a fluid center..
This method of "trying" to balance a driveshaft was fully discussed in a thread here almost 1-½ to 2 years ago, and it was unanimously agreed that this method if it worked, AT BEST, would not completely eliminate the vibrations caused by an out of balance driveshaft.
Just think of it this way, would you do this to balance your tires on the wheels? The correct way is to check for imbalances and weld weights similarly to balancing a tire and wheel, only with a balancer meant for checking driveshafts. |
Id be raising an eyebrow at first mention of WATER. Even if you were going to be putting fluid into a driveshaft (which isn't smart to begin with) why would you use water? Seems like a good way to corrode or like Bob said throw a driveshaft.
I heard a story of someone putting a drive shaft in water to balance it.Place it in the water and see if it spins.They would then mark the under side and take it out and tack a weld on or grind off until it will not spin.Then is supposed to be balanced.
Have any of you guys heard this?It is one of those tells,I knew a guy in 1950 something this is what he did etc... Maybe this urban legend somehow got mixed up with that one. |
Here's the original thread, the question asked was about balancing a driveshaft with a quart of oil.
http://hotrodders.com/forums/showthr...ght=driveshaft |
Thanks M&M, that was an interesting post. I'm glad I drained the oil out. Hopefully I won't have any problems with the driveline, but if I do I think I'll try a different machine shop.
Keep us posted on the results.
Just wanted to let everyone know, I put the driveline back into my Chevelle and took it out for a spin today. I brought the car up to about 70mph and there was no vibration from the driveline at all. Glad I drained the oil out before it had a chance to do some damage.
Just out of curiousity, you DID remember to weld the holes that you drained the fluid out of back up didn't you?
| Putting water in the intake??? | 79transam | Engine | 50 | 01-10-2006 12:23 PM |
| Best Rust Inhibitor? | bigbrowndog | Body - Exterior | 45 | 11-21-2004 08:26 PM |
| Water in Engine | billg_69gmc | Engine | 1 | 08-24-2004 09:14 PM |
| power steering from long water pump to short water pump | kellyem | Suspension - Brakes - Steering | 7 | 02-22-2004 07:22 PM |
| water pump heater hose conenction.... | oldcarguy85 | Engine | 3 | 04-07-2002 09:34 AM |
