Is this water in my engine? Pictures inside - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2009, 02:50 PM
chlsnk's Avatar
"Love what you do for a living
I noticed this awhile ago when I pulled my PCV valve to reconnect it and noticed it had a bunch of white stuff on it.I wrote it off as just lithium grease the engine was assembled with or some water from condensation on the alluminum valve covers. I changed my oil and it didnt have anything in it as far as gray bubbles or white. I pulled both of my valve covers and they are covered inside with this my rockers and everything dont have any of the white stuff on it? What is it? Is it my head gasket blowing out?
I included pictures of the head the valve covers and my breather.
Old 04-03-2009, 02:54 PM
fast68's Avatar
likes chevy trucks & boobies
are you ever missing water from the radiator?
if not then chalk it up to cold weather short trip driving and not getting the engine hot for long enough
if missing water then you may have a bad intake or head gasket issue
does it overheat ever?
over 195 or 200 ever ?
if so then a problem somewhere
also see if any air bubbles rise up into the tank or rad while running
if so then you got a gasket blown somewhere, usually head gasket does this,
big bubbles a couple every couple seconds, and usually overheating also
Old 04-03-2009, 02:57 PM
DoubleVision's Avatar
It`s common for the top of the valve covers to collect moisture due to condesation, especially on a new build or when weather conditions are favorable. If the oil in the engine isn`t milky then there`s no problem.
Old 04-03-2009, 03:18 PM
chlsnk's Avatar
Well I was alittle low on radiator fluid I didnt see any large bubbles coming to the top or any bubbles at all the enigne does smoke alittle bit.
Old 04-03-2009, 03:22 PM
fast68's Avatar
white smoke?
or blue tint in it?
Old 04-03-2009, 04:00 PM
What is the Thermostat temp? In winter, it might be necessary to run the engine 190-205 or more to bake it out Depending on whether you drive long enough and far enough to get the oil good and hot. Here in the damp and cool Northwest, it takes my 350 at least 15 miles before the engine oil temp gets up to 180-190 degrees, it takes the cooling system about 4 miles to get there. So there is a significant lag in cold weather before the oil gets hot enough just to cook the condensation water out of it.
Aluminum valve covers run too cold; fine in the south east or west but not where its damp and cold. This looks typical of an engine that doesn't get hot enough to bake the condensation out. To that, add the possibility the crankcase is insufficiently vented.
While this could be the result of, or at least augmented by a minor cooling system leak into the engine, don't forget that the largest product of combustion, thus is present in blow-by, is water. Ha, I'll bet you thought Al Gore said it was CO2. Well he probably did, but no it's H2O.
Bogie
Old 04-03-2009, 04:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I noticed this awhile ago...
Looks like condensation, I agree. Short runs, not letting the engine reach and maintain operating temp for long enough, a too-low thermostat can all contribute. DV mentioned weather, as well.
Given long enough, this is what becomes sludge. It'll also form acidic compounds that can damage bearings and cause general corrosion/rust.
IMHO, if you can't avoid the type of driving that contributes to this, increase the frequency of your oil/filter changes.
Old 04-03-2009, 05:35 PM
fast68's Avatar
oh yes PCV system good point there cobalt sir.,
is the PCV system connected properly and the valve in good shape not clogged or anything ?
make sure
needa a good clear filtered return on one side of the engine and the PCV valve connected to a strong intake manifold source on the other side of the engine
to cross ventilate and keep the crankcase clear of vapors including water moisture
or it will build up inside the crankcase and let water soak into and mix with the oil, and mess with the bearings, and so forth over time, and slowly shorten the engine's life
Old 04-04-2009, 12:44 AM
really? that much water could be caused by short trips to the store ? I would of said that too but when I seen the oil filter I would have guessed leaky head gasket ! but thats why I ask questions here you guys know more than me
Old 04-04-2009, 12:59 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That does look a lot like an oil filter- but it's a breather.
Old 04-04-2009, 07:09 AM
chlsnk's Avatar
My trips with the truck arn't even to the sture its more like running for five minuets because it just gets started to get in and out of the garage. Is there a link to somewere that shows how a PCV system should be hooked up? Thanks every one.
junkyard 13:1 compression SBC y5e06 Engine 21 07-08-2008 01:32 PM
About done with engine (pics inside) Dmaleck Engine 12 01-20-2008 04:20 PM
engine over heats, do I need a thermostat? wyomingoutlaw Engine 16 07-09-2007 08:57 PM
347 windsor hp leaking water into engine customdesignpattern@ Engine 2 07-08-2007 08:09 PM
water dripping under engine dhomsey Engine 7 09-08-2006 12:30 PM
