Water neck with o ring,seal or not to seal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2006, 05:10 PM
Hello
I have a mr gasket brand water neck with an o-ring on it. you know the cheap ones at advance/autozone. and wanted to put it on today when i realized i didn't know to seal the neck on with sealer or without. i looked on mr.gasket.com and they say you don't have to use sealer with it but i doesn't say you can if you want.
my water inlet on the manifold is a little corroded up so i figure i better use sealer/form a gasket on the water neck.
but i want to make sure i can, i have seen that the o-ring will give out after time as on the website everyones asks where they get a replacement ring!
And i have heard not to tighten these down real hard as they will warp/leak if over tightened? are these pot metal or metal with fake chrome? lol
"to seal or not to seal that is the question"!? thanks
Old 03-19-2006, 05:23 PM
Jmark's Avatar
I have never used the aftermarket 0-ring'd thermostat housing. I have used the cheapo chrome plated gasketed ones and found them to be very dangerous. The chrome is too slick to keep the hose from slipping off the housing should the clamp get a little loose. Personally, i'd go with a good cast metal gasketed housing and just paint it.
Yes, its true that if you crank down on the cheapo housings, they will distort and even crack the ears off. Never had that problem with the cast metal ones myself.
Mark
Old 03-19-2006, 05:31 PM
Hello
i cant get my hands on a metal one at the moment! i have to drive this car tommorow night so i took what i could get, the metal one i had has been misplaced by my ***** brother and it hasnt shown up in days. i would have to order one for 38.00 and would be few days before i could get it.
i have already called everyone i know that sells older parts with no luck and not enough time to drive somewhere else to look. so im having to take advantage of the cheap one, trust me i would MUCH rather have the original metal one. so im stuck for a week with this one!!
Old 03-19-2006, 05:37 PM
poncho62's Avatar
Wiki Edits: 5
Put some sealer on it, and a gasket if you wanr to, it will be fine.
Old 03-19-2006, 05:42 PM
thanks poncho, i have a gasket but i seemed like the o-ring wouldnt have any purpose if i used a gasket, ill ultra blue the sucker and hope it doesnt leak ill still go find me a oem neck on ebay cheap and suffer the cheapy chrome for now lol.
Old 03-19-2006, 05:43 PM
steve t's Avatar
ex biker, now hotrodder
they are bad for sealing, but i have run one on my 61 for years, the hose has never come off, did not use any sealer , you could take the o ring out and use a gasket
Old 03-19-2006, 07:15 PM
thanks for the replies ive sealed and mounted the neck so ill see in the morning if it works!
Old 03-19-2006, 07:25 PM
65Stanger's Avatar
Check the water, check the oil
I have cracked the ears off of them, and the best advice I can give you is to MAKE SURE THAT THE THERMOSTAT IS DEAD CENTER IN THE HOUSING! Move the housing around without the bolts on...it should be a smooth surface. Once the thermostat is dead center, and you have the gasket on (never used the o-ring), just tighten down both of the bolts evenly. If it's even and you hold the housing against the block, it won't crack. Just don't overtighten. Do you have a shop manual? Check torque.
Old 03-19-2006, 09:50 PM
MI2600's Avatar
Member# 3287
I found my local NAPA had a good selection of housings. I don't know your application, but their books were complete with pics.
Personally, I've seen the type you mentioned. They're good for about one time. The best seal is a cast iron housing and studs.
Old 03-19-2006, 09:53 PM
sbchevfreak's Avatar
Licenced Automotive Technician
If you are going to use sealant on it, I'd scuff the chrome surface up with som sandpaper or steel wool, just to give the sealant something to adhere to. If the surface is too slick, it may not "grab".
Zoop Seal coating for polished aluminum, RESULTS!!!!!!! fordSR Engine 15 02-05-2010 12:04 PM
New Water Neck Gasket 18-FEVR Engine 6 12-28-2004 09:53 AM
water neck outlet on 350sbc question 73chevyhelp Engine 8 10-15-2004 09:47 PM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
Billet Specialty water neck. TVR383 Engine 1 04-26-2003 07:13 PM
