Water Neck Replacing
915 views 5 replies 4 participants last post by  eloc431962
can you use o-ring style water neck in replacement of gasket style water neck.i bought a o-ring style but i found out i have gasket style does it make a difference? :confused:
#4 ·
Yes but you need to be careful when tightening the mounting bolts. The O ring style allows the bolt ears to be pulled down which will bend if not break them, so use caution. You can cut the ears from a gasket and place them between the parts under the bolts which will help keep you from pulling the casting's ears down too far.
Bogie
