Water neck won't fit! Help please...
My first post was to say hello and already I have a question. I tried the search function but either my issue is so twisted it isn't there or I need to learn to search better. I am in the process of dropping a SBC in my CJ7 and have come to the shiny new two piece billet water neck and the Edelbrock Performer intake. I climbed onto the bumper to screw it down, the knees hurt reminding me I am getting old, and I soon found out that the bolt spacing in the flange is too narrow for the holes in the intake! I took the one bolt out, scratched my head, climbed back on and tried it again... no go. I have about half a hole worth I can catch in the intake. I grabbed another water neck to try it out and the same thing happened. This intake was on the motor before I rebuilt it and the old chrome steel water neck fit fine as far as I recall. Am I missing something here? Is there an intake close to the SBC that I keep getting the water neck for by mistake? Did I stretch the aluminum when I torqued it down? After everything else in this conversion, something as simple as a water neck is confusing me!? Thanks in advance for any assistance!
Pretty sure all the "SBC" water necks are the same fit. And you have a stock one and it won't fit either is this what you are saying ? If not find a stock one a put it on you will be better off with it then most after-market housings JMO
Cole Last edited by eloc431962; 02-28-2011 at 07:20 PM. |
Thanks for the reply. Actually, both that I tried were the same aluminum two piece o-ring style. I had basically a stock replacement chrome model on prior to this and though I would go with a new, high speed aluminum one. I called Edelbrock and they were stumped too. I would have thought that someome somewhere would have had the same issue but they had never heard of it before. They (Edelbrock) have a two piece model as well and I'm wondering if I should just try theirs if I want to stay with an aluminum one and avoid the China aluminum ones?
At this point, I have no idea. I walked back to the stock neck and held the new flange up to it and the holes seem to line up. The problem seems to be the countersunk holes for the allen bolts in the new flange. For that matter, when I put the stock replacement, chrome one on the intake, it seems like it too is a little narrow for the holes in the intake but there is just enough room to get the bolts to thread in.
Just when the confidence is there and things seem to be going good, this kinda stuff happens... I'm on to the tranny now. Maybe it will go in without incident...
Solved, but I don't know how
Well I went to Advance Auto to see the guys and ripped open a Mr. Gasket neck similar to the one I had and checked the flange against mine. There seemed to be somewhat of a difference. We pulled down an EPS manifold and tried to match my flange up and it seemed to be much closer than mu old RPM. This, in and of itself, has no explanation. Why would one manifold have a different spacing than another? We tried the Mr. Gasket flange and it was better yet; wider spacing on the holes. So I got the neck, used the flange and my housing and it worked. Lesson learned. eBay parts can stay on eBay... This water neck came from The Speedshop just an fyi...
| Water Neck Replacing | hemi joe | Engine | 5 | 09-21-2009 02:45 PM |
| Water neck | Badazz93 | Engine | 27 | 03-29-2009 08:26 PM |
| Water neck | 7dcrzr | Engine | 17 | 08-20-2007 04:35 PM |
| New Water Neck Gasket | 18-FEVR | Engine | 6 | 12-28-2004 09:53 AM |
| Billet Specialty water neck. | TVR383 | Engine | 1 | 04-26-2003 07:13 PM |
