Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water in oil?
Thread: Water in oil?
Old 03-20-2003, 12:57 PM
Camaro2Fast4u Camaro2Fast4u is offline
Post Water in oil?
i recently built a small block 350 chevy its got eagle forged crank, h beam rods, forged flattop pistons 10.0 to 1 compression, holley systemax 2 kit, with holley alluminum heads, street dominator, lunati cam and lifters, and a holley 770 street avenger carb. last weekend i broke the cam in , and the motor has about 50 miles on it, i recently noticed that the baffle in my breather had a milky oil residue, the head gaskets are felpro the ones that the kit says to use, the motor runs tip top , and when i changed the oil after breakin and 30 miles it wasnt milky and no evidence of water was in the oil from the pan, what would cause the milky oil in my breather battle? i took the valve cover off and it is not all milky just were the oil fill cap is and the baffle for the breather. could my intake manifold be leaking, or is it head gasket?
