Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Water in oil?
Thread: Water in oil?
Old 03-21-2003, 03:41 PM
milner's Avatar
milner milner is offline
when you first started the engine , did you remove all the air locks in the cooling system. if not, it probably came out it's self. once the motor cooled down, it would suck it from the overflow, back into the rad. good luck!
