Water in oil? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2003, 12:57 PM
Post Water in oil?
i recently built a small block 350 chevy its got eagle forged crank, h beam rods, forged flattop pistons 10.0 to 1 compression, holley systemax 2 kit, with holley alluminum heads, street dominator, lunati cam and lifters, and a holley 770 street avenger carb. last weekend i broke the cam in , and the motor has about 50 miles on it, i recently noticed that the baffle in my breather had a milky oil residue, the head gaskets are felpro the ones that the kit says to use, the motor runs tip top , and when i changed the oil after breakin and 30 miles it wasnt milky and no evidence of water was in the oil from the pan, what would cause the milky oil in my breather battle? i took the valve cover off and it is not all milky just were the oil fill cap is and the baffle for the breather. could my intake manifold be leaking, or is it head gasket?
Old 03-20-2003, 01:25 PM
bullheimer's Avatar
NEVER use credit cards!
Post
might be something to due with cam lube or maybe gasoline dumped trying to start that made it past the unseated rings??? if it went away, what ya worryin about?
Old 03-20-2003, 02:26 PM
dmorris1200's Avatar
doesn't play well with others
Post
Well I don't want to say anything for sure since I can't see your engine but it's not that uncommon to get that on breathers. I forget whether it's weather related or what the exact factors are that contribute to it. I do know it's not that uncomon to remove oil fill caps from vehicles valve covers and find the underside of the cap covered with a milky substance, usually on cars that are only driven short distances and not for long drives to really heat up the engine good. As long as the oil in the pan comes out clean it's probably nothing. Usually a good working PCV system keeps the breather clean because fresh air is constantly being drawn in through it.
[ March 20, 2003: Message edited by: dmorris1200 ]</p>
BUILT FORD TOUGH
Old 03-20-2003, 06:02 PM
milner's Avatar
Post
i totally agree with dmoris1200. are you running a pcv system, if not, that is your problem. good luck!
Old 03-20-2003, 06:59 PM
Post
until tonight i only had a breather and an oil cap, now i put a pcv from the vacume port on the carb to the valve cover, and eliminated my breather, was the water coming from inside the motor? i only say this because my antifreeze was down a bit
Old 03-20-2003, 07:02 PM
New Member
Post
mine does that when its cold outside. But now that its warmed up it went away. i think it has something to do with the condensation in the air or something.
Old 03-20-2003, 07:06 PM
Post
the antifreee was low in my radiator, probably half a glass, but my res was also empty, were did it go? could it be sneeking into my motor
Old 03-21-2003, 03:41 PM
milner's Avatar
Post
when you first started the engine , did you remove all the air locks in the cooling system. if not, it probably came out it's self. once the motor cooled down, it would suck it from the overflow, back into the rad. good luck!
Old 03-21-2003, 03:51 PM
milner's Avatar
Post
forgot to mention, about your pcv system. you said you removed the air breather. you must have some way for air to enter the engine, when using a pcv valve.
Old 03-21-2003, 03:56 PM
Post
[quote]the antifreee was low in my radiator, <hr></blockquote>
Like milner said, if there was any air pockets in the system they would have worked their way out causing the level to drop. Top off the system and then keep an eye on it topping off the reservoir only. Do not keep opening the radiator cap, kep the system sealed. If the antifreeze in the reservoir keeps emptying then you may have a problem. If you have no external leaks and she's not smoking with that nasty sweet smell of a bad head gasket you're probably ok.
[quote]now i put a pcv from the vacume port on the carb to the valve cover, and eliminated my breather <hr></blockquote>
For the pcv system to work correctly you should have a pcv in one valve cover connected to a constant vacuum source and a breather in the other valve cover so you don't create a vacuum in the crankcase. The breather in the other valve cover is to allow fresh air to be drawn into the crankcase by the vacuum applied to it by the pcv.
BUILT FORD TOUGH
