Water Problem with Air Compressor - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 05-23-2007, 09:21 AM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
Originally Posted by 71gtx
I will get pics asap. The surface is 1/8th inch aluminum, sanded very thoroughly and primed with a self-etching sealer. The sealer seemed to go on better but it was a different consistency so its hard to say. The paint shop set me up right for aluminum. I feel like the gun may not be allowing enough paint to flow. I will try a different gun, pick up some diffferent rags, and possibly add a little bit more reducer and see what i get.
Did you use a wash primer or something like DP90?
PPG makes a "wash primer" for aluminum that is a very thin substrate that I would normally use on the clean aluminum and then I would use the correct color coded DP primer before applying the paint.
I just don't recall what the topcoat methods are for the wash primer and if you can apply a topcoat directly over it...which I know you can do with the DP products.
  #47 (permalink)
Old 06-04-2007, 12:51 AM
Last journal entry: Rear End Disassembly
well, problem solved guys, my cousin let me use his old enamel gun, a binks 7, and everythings working good now. looks like the lowes gravity feed was made more for base coat clear coat. i appreciate all of your help, take care and best of luck to future projects.
Custom Air Compressor Guide goleafsgo_12 Garage - Tools 13 03-13-2012 02:10 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
water pump problem rakundig Engine 15 08-10-2007 09:15 AM
need help with air compressor stingingdragon Garage - Tools 2 11-24-2006 04:52 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 05:52 PM
