Water Problem with Air Compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2007, 01:53 PM
Last journal entry: Rear End Disassembly
Hello guys, I am pretty new to painting cars. I am working on a project spraying with a gravity feed gun. I have a craftsman vertical 33gallon air compressor. I purchased a craftsman water trap/filter and mounted it stratight off of the compressor before attempting spraying. I used a hose that has the hard plastic outer shell. Well, I got water bubbles heavily in the area I tested.
I then took a DA and ran it and noticed that water was coming out heavily, but no water is collecting in the water trap. i was told i need a rubber flex hose rather than the one i have, but why isn't water trapping in the first place? any tips on how to set this up to eliminate all water?
I was also told to mount the water trap higher than the compressor to help?
Old 05-04-2007, 02:20 PM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
The reason its not catching the water is cuz when it passes through the filter right at the compressor, it hasnt FORMED water yet. The airs still hot and doesnt form condensation til it starts cooling off, further down the line. As a rule of thumb, the further from a compressor you put a filter, the better it will be utilized.
Old 05-04-2007, 02:44 PM
boatbob2
air compressor water
hi,i have a 60 gal vertical compressor.heres what i did to solve the water problem. at the fitting where the air hose would connect,i took 1/2 in galvanized pipe (hardware store,hd or lowes) and made a long U shape 1 piece of pipe 2ft long,,vertical,90 degree fitting, water hose bibb,6in long horizonontal(bottom of U shape,) vertical piece of pipe 20 in long air hose fitting on end. in use i start compressor,let it fill up,open water bibb till water drains out close bibb,and spray. every 10 minutes or so,i drain water again. i also use a toilet paper water filter in air line just before regulator.(close to gun)
Old 05-04-2007, 03:32 PM
What you have is a classic example of why it is nearly useless to mount a water separator on the compressor itself. To understand it a little better, the water in the hot air coming from the tank is still in vapor form so it will pass right through the separator unit and then as the air cools the water will then condense on the air line walls and then, well you know what happens then. To paint you NEED a complete system and the compressor and air hose are only part of this system you also need to cool the air BEFORE it reaches the separator and there are several ways of doing this with the most common being a fairly long properly run pipe from the compressor to the separator and then to the air hose, This pipe is very important to the system and should not be left out. The pipe must be routed in such a way that the water that collects on the walls will drain down into collection 'drops" where it will remain undisturbed by the air flow until it is drained. This may sound complicated and hard to do but it really is quite simple and has been covered here a bunch of times in detail so do a search first on "air lines" and maybe one on "compressor" and you will find in recent posts some info on how to do this. There are several good ways so check them out and decide which way is best for you or there are a couple of other tricks such as air coolers between the tank and separator. Do that search then get back to this thread with any questions you may have and you will find help from a bunch of guys who have already done this and have systems that work really good, if you do that search then yours will too shortly.
Old 05-05-2007, 08:35 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Your air line should slant slightly toward a 'drop' which would be, at least in my opinion, a tee (T) with the airflow going along the top part and a length of the hard line going down with a plug for easy drainage (this is essentially an improved version of an aforementioned setup). And if you have an air distribution setup with the lines going around the walls, have a real quality air dryer at the 'outlet'. Using a clean air hose is a good idea, sitting on the floor unplugged they probably get alot of junk inside of them, perhaps also some air tool oil? (put oil into air tool, plug into line, and some oil seeps back into hose and forms dirt holding residue is my theory)
The little disposable filters right by the gun isn't a bad idea either.
Old 05-05-2007, 11:15 AM
Ok it seems to be hitting me now. I am going to run a hard line from the tank about 15' or so? What type of line is this called, and will any bends or angles up or down help this? Then attach the filter to the end of this hard line, run 50' hose off of that with a disposable filter attatched to the gun. Is this correct?
Old 05-05-2007, 11:38 AM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
You can never have too many filters but place them at the end of the pipe run before the plug in for the hose...
This is a picture of my temp setup - I'll still add an air-line dryer down the road when I build an outside shed for the compressor...
This is about 100 bucks worth of copper pipe and fittings with a 50' reel hose (Lowes not sure on price its about 4 years old), the filter/regulator is from HF about 30.00
My shop is 22x40 so the retractable hose reaches all corners easily.
Copper works better for condensing the water than galvanized pipe. IMHO
Old 05-05-2007, 11:39 AM
No, Actually the hose length is not important it is the pipe that should be about fifty feet. I realize this is not always practical and the are ways around it. Your goal should be to condense as much water in the pipe between the compressor and the separator as possible and have this water drain down into collection "drops" where it can remain until it is drained. This is not nearly as hard to do as it sounds and there have been literally pages written here on how to do this, basically you will use the pipe as a heat exchanger that will cool the air thus allowing for condensation of the water vapor BEFORE it reaches the separator.
For a small shop with limited space the set up Rambo has is just about ideal, heck that would work good in a big shop
Old 05-05-2007, 04:04 PM
am i seeking 1/2" copper pipe? Rambo, how many feet of it do you hvae there? and i think lastly is i should probably run a flex hose off the compressor to the pipe for vibration purposes, correct?
Old 05-05-2007, 04:18 PM
Approx 26' total
I bought 32ft of 1/2 Schedule L (M will work but L is thicker)
Each down is approx 4' and there is 2 pet-**** drains plus the drain at the filter/regulator and the compressor.
I barely get any moisture at the filter - so far no matter how long it cycles (depends on the tool I'm using). There might be some issues when it gets hotter outside - but I'm going to add a refrigerated line dryer to the copper system later this summer.
Old 05-05-2007, 04:49 PM
Definitely use a flex line from the compressor to the hard pipe, a hydraulic hose is perfect. It will be rated far in excess of any pressure it will ever see on a compressor, it will last just about forever, it is available in any size or length and is easily found with pipe fittings. Also the lowest rated hose will be around 1500 to 2000 PSI or so and will be inexpensive so you will not need a more costly high pressure hose.
Old 05-06-2007, 06:58 AM
I find it funny that we have to be protected from ourselves. Profanity filters on a Hot Rod forum... Jeez! What's next? a V-chip for photos???
Petcock or pet-****, one is a harmless drain and the other is a rooster
Old 05-06-2007, 08:46 AM
Ok guys, I purchased the goods and am about to set it up. Heres what I'm doing:
I couldn't find threaded copper pipe so I went with galvanized. I have 10 3' galvanized pipes, going to go up and down 5 times like in Rambo's picture. At the bottom of each I will have a 5" T going down to a ball valve drain. So there will be 4 drain valves and finally the craftsman filter at the end.
Old 05-06-2007, 08:53 AM
Galvanized pipe does not cool as well as copper - but should still give you enough to condensate the water on your down runs
btw you have to sweat/solder copper pipe together I've never seen any pipe that had threads.
Make sure you use a ball valve from the compressor to the flex hose that hooks into this system. If you ever get a blowout you want to be able to cap it off!
Old 05-06-2007, 10:05 AM
I agree that Copper would have been a better choice however it is not so much so that you need to change plans, the galvanized should work just fine. Be sure and seal the threads really good and use GOOD quality fittings preferably made in USA because some of that import stuff is just plain junk.
Custom Air Compressor Guide goleafsgo_12 Garage - Tools 13 03-13-2012 02:10 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
water pump problem rakundig Engine 15 08-10-2007 09:15 AM
need help with air compressor stingingdragon Garage - Tools 2 11-24-2006 04:52 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 05:52 PM
